Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9868 Discussions
how can I get data count of uart buffer using mraa lib on intel edison board
xzhan35
Hi all,
I use read() function to read data from uart in mraa library, and I set a noblock mode, but I don't know how can I get the uart buffer data count use the ioctl() function.
I don't use arduino IDE. I programm and build the source code in edison.
Pedro_M_Intel
Hello connor.zhang,
As far as I understand the only way to get the UART buffer data count, is, as you mentioned, using the ioctl function. I didn't quite understand your question, are you having issues using iotctl?
If so, I'll post here some links that I believe you might find helpful:
http://man7.org/linux/man-pages/man2/ioctl.2.html ioctl(2) - Linux manual page
http://www.cmrr.umn.edu/~strupp/serial.html# 5_1 Serial Programming Guide for POSIX Operating Systems
Peter.
Pedro_M_Intel
Hello connor.zhang,
Peter.
xzhan35
Hi peter,
I used ioctl(fd,FIONREAD,&counter), I include , but it have error :
root@edison:~/eulerspace# gcc main2.c -o main2 -lmraa
main2.c: In function 'main':
main2.c:33:23: error: 'FIONREAD' undeclared (first use in this function)
ioctl(serialPort, FIONREAD, &counter);
KEckh
Valued Contributor III
my Guess is you are not including the necessary header files. My guess is that it is in:
# include
Carlos_M_Intel
Hi connor.zhang
Were you able to compile your code without errors and receive data in the buffer?
Regards;
CMata
xzhan35
hi CMata,
I can receive data in the buffer ,thanks a lot.
