i want to edison-to-edison communication.
http://download.intel.com/support/edison/sb/edison_wifi_331438001.pdf http://download.intel.com/support/edison/sb/edison_wifi_331438001.pdf
this document is for YOCTO linux, not ubilinux.
i was saw this thread.
but. noting happen.
i was edited some line in /etc/hostapd/hostapd.conf
# Wi-Fi Direct (P2P) #
# Enable P2P Device management
manage_p2p=1
# Allow cross connection
allow_cross_connection=1
anyone know more setting for wifi-direct in ubilinux?
also, systemctl command is not working in ubilinux.
root@ubilinux:~$ systemctl
-bash: systemctl: command not found
root@ubilinux:~$ systemctl -h
- Tags:
- WiFi
Hello insen.an,
If you would like to receive a more accurate answer regarding how to do this on Ubilinux, then you can contact Emutex with the information found in http://www.emutex.com/contact.
Nevertheless, there is information about how to create a Wi-Fi Direct connection in Yocto. In case you are interested in this option, you can check this guide: https://communities.intel.com/docs/DOC-109932 https://communities.intel.com/docs/DOC-109932. It explains how to create a P2P connection between two Edison modules and how to transfer files over it through FTP.
I hope this helps.
Peter.
Hello insen.an,
I hope this helps.
Peter.
