Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
how do you fully recover a board?
Jump to solution
Working with u-boot, I've managed to do something terrible and u-boot won't finish loading now. How to do a recovery? I've managed to get far enough along so that the flashall.sh --recovery tries to work, but it won't actually flash. I cannot find an official procedure on this.
airdamien@edibuild:~/edison$ ./flashall.sh --recovery -v
Starting Recovery mode
Please plug and reboot the board
Flashing IFWI
XFSTK Downloader Solo 0.0.0
Copyright (c) 2014 Intel Corporation
Build date and time: Oct 14 2014 15:38:56
Intel SoC Device Detection Failed: Attempt # 0
Intel SoC Device Detection Failed: Attempt # 1
Intel SoC Device Detection Failed: Attempt # 2
Intel SoC Device Detection Failed: Attempt # 3
Intel SoC Device Detection Failed: Attempt # 4
Intel SoC Device Detection Failed: Attempt # 5
Intel SoC Device Detection Failed: Attempt # 6
.Intel SoC Device Detection Found
Parsing Commandline....
Registering Status Callback....
.Initiating Download Process....
.....................................XFSTK-STATUS--Reconnecting to device - Attempt # 1
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 2
XFSTK-STATUS--Reconnecting to device - Attempt # 3
XFSTK-STATUS--Reconnecting to device - Attempt # 4
XFSTK-STATUS--Reconnecting to device - Attempt # 5
XFSTK-STATUS--Reconnecting to device - Attempt # 6
XFSTK-STATUS--Reconnecting to device - Attempt # 7
XFSTK-STATUS--Reconnecting to device - Attempt # 8
XFSTK-STATUS--Reconnecting to device - Attempt # 9
XFSTK-STATUS--Reconnecting to device - Attempt # 10
XFSTK-STATUS--Reconnecting to device - Attempt # 11
XFSTK-STATUS--Reconnecting to device - Attempt # 12
XFSTK-STATUS--Reconnecting to device - Attempt # 13
XFSTK-STATUS--Reconnecting to device - Attempt # 14
XFSTK-STATUS--Reconnecting to device - Attempt # 15
XFSTK-STATUS--Reconnecting to device - Attempt # 16
XFSTK-STATUS--Reconnecting to device - Attempt # 17
XFSTK-STATUS--Reconnecting to device - Attempt # 18
XFSTK-STATUS--Reconnecting to device - Attempt # 19
XFSTK-STATUS--Reconnecting to device - Attempt # 20
XFSTK-STATUS--Reconnecting to device - Attempt # 21
Xfstk tool error
DEBUG: lsusb
Bus 001 Device 004: ID 203a:fff9
Bus 001 Device 003: ID 203a:fff9
Bus 001 Device 002: ID 203a:fff9
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
DEBUG: dfu-util -l
dfu-util 0.8
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2014 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to mailto:dfu-util@lists.gnumonks.org dfu-util@lists.gnumonks.org
Tags (1)
Accepted Solutions
Highlighted
1 View
Re: how do you fully recover a board?
Jump to solution
thanks guys, I just figured it out. It takes moving the jumper to the other set of pins(top) and then bringing it up. then the flashall --recovery can do the work.
Highlighted
1 View
Jump to solution
You are definitely not the only one running into this.It's something which should get fixed in the script
If you don't run as root it won't work but you also won't get any warning / error message.
Highlighted
Community Manager
1 View
Jump to solution
1. Run the script as root (e.g. sudo ./flashall.sh)
2. For some reason I don't see your Edison board in lsusb output. Please connect both MicroUSB Edison ports to your computer. Run lsusb, you should be seeing the following IDs:
8087:0a9e - This is Edison DFU
0403:6001 - FTDI - Serial to USB Interface
Also start a serial console, it might spit some useful info (sudo screen /dev/ttyUSB0 115200).
Highlighted
1 View
Jump to solution
... and obviously the switch put away from the big USB socket but towards the micro USB one (if using the Arduino baseboard)
Highlighted
Jump to solution
Highlighted
1 View
Jump to solution
I currently have the same problem with the command "sudo ./flashall.sh --recovery"
Would you help me by explain what JUMPER and what PINS you mentioned about?
Highlighted
1 View
Jump to solution
Hi - I'm also not having any luck with the --recovery option, here is my output (this is with the Arduino board).
Update: the recovery process was successful after pressing the reset button on the board, and attempting it again.
Which jumpers/pins are you referring to?
Flashing IFWI
XFSTK Downloader Solo 0.0.1
Copyright (c) 2015 Intel Corporation
Build date and time: May 2 2015 15:34:00
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 3
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 4
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 5
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 6
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 7
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 8
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 9
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 10
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 11
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 12
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 13
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 14
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 15
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 16
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 17
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 18
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 19
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 20
...................................XFSTK-STATUS--Reconnecting to device - Attempt # 21
Xfstk tool error
DEBUG: lsusb
Bus 001 Device 005: ID 0bda:0151 Realtek Semiconductor Corp. Mass Storage Device (Multicard Reader)
Bus 002 Device 002: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
Bus 002 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 002 Device 004: ID 046d:c52f Logitech, Inc. Wireless Mouse M305
Bus 001 Device 046: ID 8086:e005 Intel Corp.
Bus 002 Device 030: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
DEBUG: dfu-util -l
dfu-util 0.8
Thanks!
Highlighted
1 View
Jump to solution
airdamien
