Intel® Makers
9881 Discussions
how galelio will work with wifi adapter
FATA
hi all
I have connected tenda W311M to gelelio gen2 board but when i am doing ifconfig wlp0s20f3u1 10.242.140.12 up i am getting below error-
root@quark:~# ifconfig wlp0s20f3u1 10.242.140.12 up
[ 939.545764] ieee80211 phy1: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 939.557710] ieee80211 phy1: rt2x00lib_request_firmware: Error - Failed to request Firmware
ifconfig: SIOCSIFFLAGS: No such file or directory
I want to
  1. Set up ip address of wlp0s20f3u1
  2. Ping external host's WiFi device
Please tell me how to do that-
Sergio_A_Intel
What image are you using? According to http://mitchtech.net/realtek-wireless-dongle-rt3070-on-the-raspberry-pi/ Ralink/Realtek Wireless Dongle (rt3070) on the Raspberry Pi - MitchTech | MitchTech you need to make the firmware available to the system by placing it in /lib/firmware/.
Check to see if you have the module needed using lsmod.
Sergio
Carlos_M_Intel
Hi farazata,
Do you have updates on this?
Which image are you using? How are you setting your network?
Are you using a static IP?
Charlie
