Intel® Makers
9881 Discussions
how to access my home network from outside
nDE_S
Hi
To do that I configured my Iot cloud analytics (https://drive.google.com/file/d/0B9gPdWq4OH-XdlpaZHBBeGZiYnM/view?usp=sharing https://drive.google.com/file/d/0B9gPdWq4OH-XdlpaZHBBeGZiYnM/view?usp=sharing) and now (using iotkit.h) I can read temperature in my network. But when I'm out of my network What's the best solution ?
Yesterday I fixed static ip in my Intel Edison. I have account in DynDns and I have a Hostname now. I understand about port forwarding.
In Raspberry pi, I used ddclient (apt-get install ddclient) to dynamic DNS. I trying use ddclient in Edison and have errors:
root@neuberfran:~# ddclient -v
Can't locate Sys/Hostname.pm in @INC (you may need to install the Sys::Hostname module) (@INC contains: /etc/perl /usr/lib/perl/site_perl/5.20.0/ /usr/lib/perl/site_perl/5.20.0 /usr/lib/perl/vendor_perl/5.20.0/ /usr/lib/perl/vendor_perl/5.20.0 /usr/lib/perl/5.20.0/ /usr/lib/perl/5.20.0 /usr/local/lib/site_perl /usr/lib/perl/5.20.0 .) at /usr/sbin/ddclient line 25.
BEGIN failed--compilation aborted at /usr/sbin/ddclient line 25.
Help me please
Sergio_A_Intel
Go to the Linux console and type:
wget http://sourceforge.net/projects/ddclient/files/latest/download http://sourceforge.net/projects/ddclient/files/latest/download
tar –xvf download
cd ddclient-3.8.3/
Now, follow the steps here https://github.com/wimpunk/ddclient wimpunk/ddclient · GitHub for the installation steps for your OS.
Let me know if this works
Sergio
nDE_S
Thank's Sergio,
I've done this. And I changed ddclient.conf. And I put ddclient in /usr/sbin/
After
cp sample-etc_rc.d_init.d_ddclient /lib/systemd/system/ddclient
root@neuberfran:/lib/systemd/system# systemctl enable ddclient
Failed to execute operation: Bad message
root@neuberfran:/lib/systemd/system# systemctl start ddclient
Failed to start ddclient.service: Unit ddclient.service failed to load: Bad message. See system logs and 'systemctl status ddclient.service' for details.
root@neuberfran:~/ddclient-3.8.3# ddclient -v
I think that is because libjson-perl package
How to install libjson-perl package in yocto image ?
nDE_S
Intel_Alvarado,
I installed perl-module-sys-hostname and now I have new error (Can't locate IO/Socket.pm)
root@neuberfran:~# opkg install perl-module-sys-hostname
Installing perl-module-sys-hostname (5.20.0-r1) on root.
Downloading http://repo.opkg.net/edison/repo/core2-32/perl-module-sys-hostname_5.20.0-r1_core2-32.ipk http://repo.opkg.net/edison/repo/core2-32/perl-module-sys-hostname_5.20.0-r1_core2-32.ipk.
Configuring perl-module-sys-hostname.
Can't locate IO/Socket.pm in @INC (you may need to install the IO::Socket module) (@INC contains: /etc/perl /usr/lib/perl/site_perl/5.20.0/ /usr/lib/perl/site_perl/5.20.0 /usr/lib/perl/vendor_perl/5.20.0/ /usr/lib/perl/vendor_perl/5.20.0 /usr/lib/perl/5.20.0/ /usr/lib/perl/5.20.0 /usr/local/lib/site_perl /usr/lib/perl/5.20.0 .) at /usr/sbin/ddclient line 27.
BEGIN failed--compilation aborted at /usr/sbin/ddclient line 27.
The other solution (for the future) is that : http://mkaczanowski.com/golang-build-dynamic-dns-service-go/ http://mkaczanowski.com/golang-build-dynamic-dns-service-go/
But I have error with NSUPDATE package
root@neuberfran:~# opkg install nsupdate
Unknown package 'nsupdate'.
Collected errors:
opkg_install_cmd: Cannot install package nsupdate
Sergio_A_Intel
I'm trying to install the same package as you and I'm receiving the same error. When typing ddclient I get the same error. I tried to install the libjson-perl package and received a similar error to the one you are receiving now. The error was: Can't locate lib.pm in @INC…I then followed the steps of your last reply and managed to install perl-module-sys-hostname. This didn't resolve the error. I then tried to install nspudate and libio-socket-ssl-perl. According to some users that is the solution to the error however they seem not to be compatible with the Yocto version of the Edison. What image are you using?
One option to get those packages and make sure they are included in your image would be to create your own image and add the files you need.
Sergio
nDE_S
Hi ntel_Alvarado,
About this site http://cgit.openembedded.org/openembedded/tree/recipes/ddclient/ddclient_3.6.3.bb openembedded - Classic OpenEmbedded Development Tree
I install everything via opkg and ddclient worked.
But now I stay have problems to keep wifi and fixed ip (192.168.1.XXX) working together
I change /etc/hostname and /etc/hosts files. my wireless network this alone disabling
root@neuberfran:~# configure_edison --version
159
Now I have this error:
root@neuberfran: ddclient
~# WARNING: file /var/cache/ddclient/ddclient.cache, line 3: Invalid Value for keyword 'ip' = ''
Sergio_A_Intel
To what have you changed the file /etc/hosts? For the /etc/hostname, the proper way to change the hostname of the Edison is to use configure_edison –setup or configure_edison –name.
Using image 159 if you use the command reboot you're not retaining the IP address?
Sergio
LCorn3
Or in the alternative, just use https://ngrok.com/ NGROK Way easier. Nothing to download, nothing to change. Keep using your localhost and existing ip address. Not sure about the security model, though. Its fine for software prove-out, not sure I'd use it for ongoing operations.
nDE_S
hI
Intel_Alvarado
Hostname here its OK
root@neuberfran:~# hostname
neuber.dyndns.xxx.xxx.
according thsi link:
https://communities.intel.com/thread/55880?start=0&tstart=0 https://communities.intel.com/thread/55880?start=0&tstart=0
User: DimitriM suggests that the command
"systemctl enable wpa_supplicant" to make Edison connect to Wifi automatically after reboot does not work with this static IP setup.
I'm having this problem and more. I have to disconnect my laptop usb cables (not just give the reboot command) and then restarted oh yes I command: configure_edison --wifi
I'm really trying to install: NSUPDATE.
I am participating in a mailing list to do this.
I'm trying to to this: http://mkaczanowski.com/golang-build-dynamic-dns-service-go/ http://mkaczanowski.com/golang-build-dynamic-dns-service-go/
Collected errors:
I see: "nsupdate to push updates on records. It is a part of the bind project, so it can be found in bind-tools or bind-clientpackages."
root@neuberfran:~# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from http://8.8.8.8/ 8.8.8.8: seq=0 ttl=53 time=55.101 ms
64 bytes from http://8.8.8.8/ 8.8.8.8: seq=1 ttl=53 time=32.649 ms
64 bytes from http://8.8.8.8/ 8.8.8.8: seq=2 ttl=53 time=32.983 ms
^C
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 32.649/40.244/55.101 ms
root@neuberfran:~# opkg install bind-client
Unknown package 'bind-client'.
Collected errors:
* opkg_install_cmd: Cannot install package bind-client.
root@neuberfran:~# opkg install bind-tools
Unknown package 'bind-tools'.
Collected errors:
* opkg_install_cmd: Cannot install package bind-tools.
nDE_S
Sergio_A_Intel
Do you have any updates on this case? If you're looking to go with LBC's suggestion you can also take a look at https://www.npmjs.com/package/ngrok ngrok for additional information and steps to install ngrok. I'd suggest you to try with this approach.
About the nsupdate package, you're not going to download that specific package using that command if you're communicating with AlexT's repository, because that package is not available in the repo. If you want that package you need to find another repo that is compatible with Edison or download and install the package another way. To look at the packages available in AlexT's repo look at http://repo.opkg.net/edison/repo/ Index of /edison/repo
Sergio
nDE_S
Hi
Intel_Alvarado,
I can't solved.
I'm not trying Alex_T package. I'm using github Alex_T to question about NSUPDATE
I will insist on install NSUPDATE and/or solve problems with DDCLIENT (Here I have dynamic IP)
1) What you investigated about : put statit ip in intel edison with yocto image?
2.1) As I said, I am participating of the mail list of the yocto project and they could not help me with Dynamic DNS package recipes to put in yocto image (
3.1 – Adding standard Yocto packages in the image :https://software.intel.com/en-us/node/593592 IoT - Creating Custom Intel® Edison Images | Intel® Developer Zone
2.2/Do you can help me with this or with error correction ddclient/nsupdate?
Sergio_A_Intel
If your goal is to install nsupdate from the source then you have to make kernel modifications. You'd have to add the packages to the images and build your own image. For details on how to build your image look at the Edison BSP: http://www.intel.com/content/www/us/en/support/boards-and-kits/000005616.html Board Support Package (BSP) User Guide for Boards and Kits . The steps in the BSP are similar to the ones here https://software.intel.com/en-us/node/593592 IoT - Creating Custom Intel® Edison Images | Intel® Developer Zone .
If you need a static IP take a look at . It has detailed steps to configure a static IP.
Sergio
nDE_S
LBC,
LBC 3
ngrok Need pain. not good
root@neuberfran:~/ngrok# ./ngrok http 8999 --hostname *.neuberfran.xxxx.zzz
Tunnel session failed: Custom hostnames are only available for paid plans. Signup at https://ngrok.com/signup https://ngrok.com/signup
LCorn3
Ngrok just recently changed their pricing. It was all free a few months ago. (here kids, free Cocaine. its free ?)
I do see a "Free Plan"
For quick demos and other simple tunneling needs.
HTTP/TCP tunnels on random URLs/ports
1 online client
How many clients have to address this home based device at a time? Shouldn't this work for you, free? You can go the static IP route, but a whole lot depends on your internet service provider. Generally they block that sort of behavior, they never ever want a home user to be hosting a website.... Look at your service provider's terms of service. You may also need to make some mods to your home router firewall settings to make that work.
oops.. I just read your thing again... get rid of the name 'neuberfran' and simply use IP addressing (192.168.0.15) when you make your ngrok call.
in fact, isn't the command as easy as: $ ngrok 8080 ??
and the return should look something like this:
ngrok (Ctrl+C to quit)
Tunnel Status online
Version 1.7/1.7
Forwarding http://z4182320.ngrok.com http://z4182320.ngrok.com -> 192.168.0.15:8080
Forwarding https://z4182320.ngrok.com https://z4182320.ngrok.com -> 192.168.0.15:8080
Web Interface 192.168.0.15:4040
# Conn 0
Avg Conn Time 0.00ms
nDE_S
LBC,
The command is easy ! It is similar to heroku
I pay DynDNS plan and I think use this and port forward in my router.
I'm having trouble to put static IP and and this continues running when you restart the intel edison if have a power failure here
in Ubilinux I'm earliest. If you can help-me: http://www.emutexlabs.com/forum/general-questions/96-error-to-run-node-js-application-in-intel-ediso... 153 EmutexLabs
about this site:
one people said: "mraa doesn't seem to support node 0.12.x."
I thkin: and not support node v5.4.0 also. I need to know more about this
Sergio_A_Intel
Were you able to try LBC's suggestion? Do you still need help with this case?
Sergio
nDE_S
, Intel_Alvarado,
Yes, I need more help. I will not use LBC suggestion Because price. I receive email of the ngrok
Do you know if mraa work with node.js version V4.0.0 or v4.2.0 or v5 ??? Or only with 0.10 ??
I stay doing a backup of the my intel edison. I used (in ubuntu PC prompt) this command : dd if=/dev/sdb of=/dev/sdc bs=1M (see in Gparted)
My question about this is: If (to restore) I use dd if=/dev/sdc of=/dev/sdb bs=1M. This is will erase all data of the intel edison (which already have the new yocto version running) ?
e.g.: I new edison yocto version I can put static IP. In older version, I can't.
Sergio_A_Intel
You can check the version of node with node –version and the version of the mraa library with opkg info libmraa0. I'm using node v0.10.38 and libmraa0 0.7.3 and they work properly. What versions do you have?
The dd command shouldn't delete your Edison's data. The dd command is used to copy the files from one device to another. The command just as you are using it will just clone from one partition to another.
Regarding your last statement about static IP issues why don't you upgrade your Edison with an older version to the newest version?
Sergio
nDE_S
Hi
Intel_Alvarado,
In edison with yocto I don't have problems with node.js. I have problems with DDNS. ngrok Need pain. not good
I'm trying solve problems with DDCLIENT in intel edison with yocto.
In intel edison with ubilinux ddclient worked. But I still wait debian jessie to have a gcc 4.9 and put node.js 4.2 is easy
Sergio_A_Intel
What specifically is your issue with DDNS? Were you successful installing nsupdate? Did you follow our suggestion to install nsupdate from source? What is your current goal? What are your problems with ddclient?
Sergio
