Intel® Makers
9880 Discussions
how to bring serial terminal setup for intel galileo gen 2 Nneed help asap
RVaid
Using sudo screen /dev/ttyUSB0 115200 IS NOT WORKING. I AM GETTING AN ERROR SAYING NO SUCH FILE OR DIRECTORY
Pedro_M_Intel
Hello RohiniBMSCE23,
Are you using Galileo's serial cable?
If you don't use http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-galileo-boards/000006343.html the appropriate cable to connect to the Galileo's FTDI port you won't be able to connect to your board's terminal.
If you are using the appropriate cable maybe there is already a device called USB0 on your PC and your Galileo might be being detected with another name. To determine this you can take two screenshots of the output of the command ls /dev/ | grep USB, one with the board disconnected and one with the board connected.
Peter
Pedro_M_Intel
Peter
RVaid
Thanku Peter ! It was of much help. I will update you soon .
