Community
cancel
Showing results for
Search instead for
Did you mean:
MHamd2
how to connect webcam to intel galileo gen 2
Jump to solution
hello i need a problem with webcam
i cannot find the tutorial that how to connect webcam to galileo gen 2 with c++.
so, what can i do?
Community Manager
Hello @marciarzky,
Thanks for reaching out!
The latest Galileo image (which can be downloaded from https://software.intel.com/en-us/iot/hardware/galileo/downloads) includes the UVC driver, so as long as you are working with a UVC compatible camera, you will be able to interact with your camera using your Galileo. You can check that your camera is being detected with the command ls /dev/video*.
You can in fact check this entry to see how a user used his camera with Galileo http://allskyee.blogspot.com/2015/04/webcam-using-motion-on-intel-galileo.html.
Now that you know that your camera is compatible with Galileo, then you can start programming for it. Since you are trying to create a C script you will be able to find many examples on the web, for example:
https://gist.github.com/bellbind/6813905
There are even libraries for UVC camera such as libuvc, you might be interested in checking it and taking a look at its examples. This library can be found in:
https://github.com/ktossell/libuvc
I hope this information helps you,
Pedro M.
Community Manager
Hello @marciarzky,
Pedro M.
