hi all,
I try use BSP 1.2.0 and build its SDK, but I find when I build the application, it will generate x86 include 'cmov' instruction that is not support by Quark.
Do you have any solution that I can let gcc not generate the cmov instruction code?
ps. I try to build gforth-0.7.3.
wenij
o....
I review its configure file and check it have miss configure to check as "-march=athlon64"
remove it, then the cmov was not be used .....
Sorry, for this fail post ....
o....
