Intel® Makers
9873 Discussions
how to install v4l2-utils on intel edison ?
Community Manager
hello everyone,
how to install v4l2-utils on intel edison ? or how to check whether it is already installed or not...
if not, how can i install it on my intel edison mini breakout board.
Pedro_M_Intel
Hello mailto:falak.desai@yahoo.com falak.desai@yahoo.com,
You could download the v4l-utils source with the command git clone git://linuxtv.org/v4l-utils.git v4l-utils and build it from source with the instructions contained in the package or you could set up http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html AlexT's repo, he has version 1.0.1. Let me know if you need help setting up the repo on your board.
Peter.
Pedro_M_Intel
Peter.
Community Manager
I downloaded v4l-utils from http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html AlexT's repo, but when I run the following command, it gives an error:
COMMAND: v4l2-ctl
ERROR: -sh: v4l2-ctl : command not found
Pedro_M_Intel
I installed both libv4l and v4l-utils and my Edison does recognize the command v4l2-ctl. Did you only install v4l-utils? Try installing libv4l too.
Peter.
Community Manager
Hi Peter,
I installed both libv4l and v4l-utils as suggested... but still I'm getting the same error message..
COMMAND: v4l2-ctl
where am I wrong ? can u please guide me ..
Pedro_M_Intel
That is really weird, I just reflashed my Edison to see if I had any packages that was making my Edison to have a different behavior to yours. I just installed both libv4l and v4l-utils and the command v4l2-ctl worked. I suggest you to reflash your Edison to the latest image maybe that solves the issue.
Peter.
Community Manager
Hi Peter,
Its working now.
Thank you very much.
Pedro_M_Intel
I'm glad to help. If have any other doubts, don't hesitate to come back to the community.
Peter.
