Intel® Makers
9880 Discussions
how to play mp3 in python on intel edison
KNguy20
Hi all,
Are there any ways to play mp3 in python on intel edison
I try pyglet but don't know to install AVbin on intel edison
would you mind helping me
thank you and regards,
Khoa
Community Manager
Hi Khoa,
We tried to install AVbin on the Intel Edison and we could not do it, but we found another way to play mp3 files using the mpg123 library, this library is in AlexT repo so you can use opkg to download it (http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html), after you updated the opkg you can install mpg123 using the command: opkg install mpg123.
Once you have mpg123 you can play any mp3 file with the following command: mpg123 filename.mp3.
If you want to do this process in Python just create a .py file and use the next lines:
import os
os.system("mpg123 filename.mp3")
I hope this works for you,
-Leonardo
Community Manager
Hi Khoa,
import os
-Leonardo
