Community
cancel
Showing results for
Search instead for
Did you mean:
sk23
New Contributor II
https://communities.intel.com/docs/DOC-111103
Jump to solution
Hi ,
I am not able to edit the file.it seems as folder.
Please do need full.
I
Community Manager
Hello IoT_srinivas,
What's happening is that you are trying to write text in a directory, if I'm not mistaken you entered the command "vi /lib/systemd/system/". You should have added the file that you wanted to write on, for example, "vi /lib/systemd/system/blinkWithSockets.service"
Peter.
Community Manager
Hello IoT_srinivas,
Peter.
