Intel® Makers
9868 Discussions
i can't Set up a serial terminal
rthat
i can't Set up a serial terminal. after inserting bootable sd card on lintel galileo g2
first i install http://www.ftdichip.com/Drivers/CDM/CDM%20v2.12.00%20WHQL%20Certified.exe FTDI driver for Windows.then set up the PuTTY with Connection type select Serial., speed 115200 ,and COM port of my intel galileo
then clike on "open"
blank screen opened
then press the Enter key twice. i cant see login screen. any change on black screen
Pedro_M_Intel
Hello Rashid_Thattayil,
Which version of the FTDI driver did you download? If you have a 32 bit PC you need http://www.ftdichip.com/Drivers/CDM/CDM%20v2.12.14%20WHQL%20Certified.zip this one and if you have a 64 bit PC you need http://www.ftdichip.com/Drivers/CDM/CDM%20v2.12.14%20WHQL%20Certified.zip this one. Those are the latest versions of the FTDI drivers.
Could you show us the devices that are being detected on your device manager and a screenshot of how you are setting PuTTY?
Peter.
Carlos_M_Intel
Hi Rashid_Thattayil
Have you been able to use the Serial Terminal?
Are you using a FTDI cable of 3.3V or 5V?
Charlie
