Community
cancel
Showing results for
Search instead for
Did you mean:
ian1
i have problem for USB detected by custom Edison board
I was referenced Sparkfun Base board to connect webcam logitech C110 & gyro sensor in my custom board
see reference link below
https://cdn.sparkfun.com/datasheets/Dev/Edison/Base_Block.pdf https://cdn.sparkfun.com/datasheets/Dev/Edison/Base_Block.pdf
https://www.sparkfun.com/products/13045 SparkFun Block for Intel® Edison - Base - DEV-13045 - SparkFun Electronics
schematic file & top-view file also uploaded.
My problem is OTG function not worked.
any other function is worked
i think 100% sure that Sparkfun base block and my custom board are same
especially, OTG part there are same circuit
nothing special.
but connector is not OTG cable & socket is molex. see that uploaded picture
i sure that cable not a problem because i tested a lot
do any know about Edison OTG interface mechanism clearly?
what i missed?
additional, dmesg command when i connecting camera
[ 60.482142] pmic_ccsm pmic_ccsm: USB ID Detected. Notifying OTG driver
[ 61.031905] dwc3-host dwc3-host.2: xHCI Host Controller
[ 61.032538] dwc3-host dwc3-host.2: new USB bus registered, assigned bus number 1
[ 61.032844] dwc3-host dwc3-host.2: irq 34, io mem 0xf9100000
[ 61.032987] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 61.033011] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 61.033032] usb usb1: Product: xHCI Host Controller
[ 61.033051] usb usb1: Manufacturer: Linux 3.10.98-poky-edison+ dwc-xhci
[ 61.033070] usb usb1: SerialNumber: dwc3-host.2
[ 61.033834] xHCI xhci_add_endpoint called for root hub
[ 61.033854] xHCI xhci_check_bandwidth called for root hub
[ 61.034122] hub 1-0:1.0: USB hub found
[ 61.034166] hub 1-0:1.0: 1 port detected
[ 61.034754] dwc3-host dwc3-host.2: xHCI Host Controller
[ 61.035151] dwc3-host dwc3-host.2: new USB bus registered, assigned bus number 2
[ 61.035314] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 61.035338] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 61.035358] usb usb2: Product: xHCI Host Controller
[ 61.035377] usb usb2: Manufacturer: Linux 3.10.98-poky-edison+ dwc-xhci
[ 61.035396] usb usb2: SerialNumber: dwc3-host.2
[ 61.036041] xHCI xhci_add_endpoint called for root hub
[ 61.036061] xHCI xhci_check_bandwidth called for root hub
[ 61.036515] hub 2-0:1.0: USB hub found
[ 61.036559] hub 2-0:1.0: 1 port detected
[ 61.172546] pmic_ccsm pmic_ccsm: USB VBUS Removed. Notifying OTG driver
[ 61.172791] dwc3-host dwc3-host.2: remove, state 4
[ 61.172844] usb usb2: USB disconnect, device number 1
[ 61.173472] xHCI xhci_drop_endpoint called for root hub
[ 61.173492] xHCI xhci_check_bandwidth called for root hub
[ 61.174283] dwc3-host dwc3-host.2: USB bus 2 deregistered
[ 61.174726] dwc3-host dwc3-host.2: remove, state 1
[ 61.174767] usb usb1: USB disconnect, device number 1
[ 61.175836] xHCI xhci_drop_endpoint called for root hub
[ 61.175856] xHCI xhci_check_bandwidth called for root hub
[ 61.176760] dwc3-host dwc3-host.2: USB bus 1 deregistered
[ 61.274790] pmic_ccsm pmic_ccsm: USB VBUS Detected. Notifying OTG driver
Community Manager
Hi Insen.an,
That's a weird problem, we checked your board schematic and the Sparkfun board schematic and yes they are the same, we also compare your schematic with the http://www.intel.com/content/www/us/en/support/boards-and-kits/000005699.html Edison Breakout Board schematic and they are very similar.
About the dmesg command, it looks like that the problem is not in the hardware part because the camera is detected, right? So, I would like to ask you the following questions:
Have you used the Edison as a device? To flashing it, or other process. If you do, do you have problems with it?
Have you connected another device on the port? Please try with another device to check if it works.
I will be waiting for your answers.
-Leonardo
Community Manager
Hello Insen.an,
Do you still have problems with the OTG port? Did you try to use your board as a device?
Remember that I'm here waiting for your answers to help you.
-Leonardo
