Community
cancel
Showing results for
Search instead for
Did you mean:
wcaro
i need reading an index.html in the Galilean intel sd for web server?
I need to read the index.html and send it to the client
something like that:
file= fopen("/media/realroot/index.htm" , "r");
client.write( file ); // send web page to client
The example below is with external sd, but I need the same but with the sd where Linux is installed
else { // web page request
// send rest of HTTP header
client.println("Content-Type: text/html");
client.println("Connection: keep-alive");
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
thanks for the help you can give me
Pedro_M_Intel
Hello wilson caro,
I'm sorry; I'm a little confused by your post. Specifically with the following sentence:
"...The example below is with external SD, but I need the same but with the SD where Linux is installed..."
I mean, when you are using Galileo with the full Yocto image installed on an SD Card, you can also use it as an external massive storage device which is in fact found in /media/realroot.
Now, how do you want to send the file to your client? Which interface will you be using?
What is your client? Is it another board, a PC, etc.? You are using the Arduino IDE for this project, right?
Peter.
wcaro
thanks for the reply, and excuse my English, I speak Spanish or Italian.
I want is to use the example of the web server, but do not want the website within the sketch, as is normally done. example:
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Connection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("");
// add a meta refresh tag, so the browser pulls again every 5 seconds:
client.println("");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("");
I want to read the index.html copied into the sd "intel Galieo gene 2" and send it. The following is an example with Arduino Mega or one. external SD module has not integrated, as in the Galilean intel.
client.println();
// send web page
if (webFile) {
webFile.close();
the following link is an example of what I want. but I want to do with the "Galilean intel gene 2".
https://startingelectronics.org/projects/arduino-projects/web-server-two-temperature-gauges/ https://startingelectronics.org/projects/arduino-projects/web-server-two-temperature-gauges/
thanks for the help.
Pedro_M_Intel
I see, in that case, wouldn't a sketch such as 'ReadWrite.ino' (found in the example>SD section of the Arduino IDE) help? I mean, you can adapt it to your own sketch and use it to read the html file found in the Galileo's SD, then you can create the web server using that file.
Since you are trying to interact with the file system, there is a blog written by mhahn that you might find of interest: https://software.intel.com/en-us/blogs/2014/09/22/efficient-communication-between-arduino-and-linux-... Efficient communication between Arduino* and Linux native processes. I suggest you to take a look at it, it may help you in this or future projects.
Peter.
