Intel® Makers
9881 Discussions
i2c and digital out/in web server
KSels
New Contributor II
Where can I find a easy guide on how to Control/read gpio pins and i2c modules from the Intel edison / Intel Galileo Gen 2 web server.
I want to use JavaScript, I am using Intel XDK.
On the Intel edison I am using the mini breakout Board and not the arduino Board.
Sergio_A_Intel
Hi KimLorentz,
The information I could find about controlling I2c,using Java Script in the XDK is mostly from other community threads. There are also other guides users have made using the Edison. Some use Java Script in the XDK but not I2C. Some use I2c in the XDK but are not using Java Script.
These are some of the threads I believe would help you the most:
https://github.com/intel-iot-devkit/mraa/tree/master/examples/javascript mraa/examples/javascript at master · intel-iot-devkit/mraa · GitHub
https://m2aglabs.com/2015/02/24/intel-edison-and-i2c-sensors-with-xdk/ Intel Edison and I2C sensors with XDK – m2ag.labs
Sergio
Sergio_A_Intel
Hi KimLorentz,
Sergio
