Community
cancel
Showing results for
Search instead for
Did you mean:
sk23
New Contributor II
i2c smbus not working on edsion
Hi ,
https://github.com/ControlEverythingCommunity/HTS221/tree/master/Python HTS221/Python at master · ControlEverythingCommunity/HTS221 · GitHub
I was using above python code for HTS221.
Error :
python hts221.py
Traceback (most recent call last):
File "hts221.py", line 2, in
import smbus
ImportError: No module named smbus
Please provide the steps to resolve above issue.
import smbusimport time# Get I2C busbus = smbus.SMBus(1)# HTS221 address, 0x5F(95)# Select average configuration register, 0x10(16)<td class="blob-num js-line-number" data-line-number="15" style="box-sizing: border-box; padding: 0px 10px; width: 50px; min-width: 50px; font-family: Consolas, 'Liberation Mono', Menlo, Courier, monospace; font-size: 12px; line-height: 20px; color: rg...
Community Manager
Hi Srinivas,
I would like to know some more about your project so we can help you better.
Which image are you using?
Also, did you attach the log for some reason? I'm not sure why you attached it. If you could explain us I would really appreciate it.
Now, regarding the error, first try to install i2c-tools from the AlexT repository using opkg. Then try to install smbus with these instructions:
pip install cffi
pip install smbus-cffi
You can check some more discussion on this following this link, /thread/61160 https://communities.intel.com/thread/61160.
-Pablo
sk23
New Contributor II
Hi Pablo ,
I was unable to install ccfii and smbus-cffi
I was getting below error
root@edison:~# pip install cffi
-sh: pip: command not found
root@edison:~# pip install smbus-cffi
Please do need full.
Community Manager
Hi Srinivas,
This is due to pip not being installed on your Edison. You should avoid the error if you install it.
Here are the steps to do so:
1. Setup the Edison repo by replacing anything you have in the /etc/opkg/base-feeds.conf file with the following:src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all
src/gz edison http://repo.opkg.net/edison/repo/edison http://repo.opkg.net/edison/repo/edison
src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32 http://repo.opkg.net/edison/repo/core2-322. Setup the IoT repo by running the following commands:echo "src intel-iotdk http://iotdk.intel.com/repos/3.0/intelgalactic/opkg/i586 http://iotdk.intel.com/repos/3.0/intelgalactic/opkg/i586" > /etc/opkg/intel-iotdk.conf3. Run the following command: opkg update4. Install pip by running the following commands:wget https://bootstrap.pypa.io/get-pip.py https://bootstrap.pypa.io/get-pip.py --no-check-certificate python get-pip.py
-Pablo
Community Manager
Hi Srinivas,
Any updates on this case?
-Pablo
