hi all,
I am trying to install mysql module for python with pip however I am getting the following errors :
root@edison:~# pip install MySQL-python
Collecting MySQL-python
/usr/lib/python2.7/site-packages/pip-8.0.2-py2.7.egg/pip/_vendor/requests/packages/urllib3/util/ssl_.py:315: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. For more information, see https://urllib3.readthedocs.org/en/latest/security.html# snimissingwarning https://urllib3.readthedocs.org/en/latest/security.html# snimissingwarning.
SNIMissingWarning
/usr/lib/python2.7/site-packages/pip-8.0.2-py2.7.egg/pip/_vendor/requests/packages/urllib3/util/ssl_.py:120: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/latest/security.html# insecureplatformwarning https://urllib3.readthedocs.org/en/latest/security.html# insecureplatformwarning.
Using cached MySQL-python-1.2.5.zip
Complete output from command python setup.py egg_info:
sh: mysql_config: command not found
Traceback (most recent call last):
File "", line 1, in
File "/tmp/pip-build-YYEv1x/MySQL-python/setup.py", line 17, in
metadata, options = get_config()
File "/tmp/pip-build-YYEv1x/MySQL-python/setup_posix.py", line 43, in get_config
libs = mysql_config("libs_r")
File "/tmp/pip-build-YYEv1x/MySQL-python/setup_posix.py", line 25, in mysql_config
raise EnvironmentError("%s not found" % (mysql_config.path,))
EnvironmentError: mysql_config not found
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-YYEv1x/MySQL-python
can someone please let me know how i can install this module? I am getting this exact error when i try to install other modules too, why is this >?
Hello a_Monteiro,
I was reading some posts online about the same issue and according to them it was because of the dependencies libmysqlclient-dev and python-dev. However, I installed them both and even though the error changed, I still couldn't install it so I installed the following packages and I was able to install MySQL-python with the pip command:
libmysqlclient-dbg
libmysqlclient-r
libmysqlclient-r-dev
libmysqlclient-r-staticdev
libmysqlclient-staticdev
libmysqlclient18
libmysqld-dev
libmysqlclient-dev
libmysqld18
Peter.
Hello a_Monteiro,
libmysqlclient-dbg
libmysqlclient-r
libmysqlclient18
libmysqld-dev
libmysqlclient-dev
libmysqld18
Peter.
