Intel® Makers
9872 Discussions
integrate C1000 with Dish washing machine
IAkin
How can I integrate C1000 with Dish washing machine such that I can monitor temperature, water levels and other statistics remotely from the commercial machine?
Bolero wireless has a smiliar solution here (http://www.bolerowireless.com/main4/IOT-Warewash-Monitoring-Solution.html Single Post ) Is this oissible with Intel's c1000?
Michelle_C_Intel
The C1000 is suitable for this use case.
However , are you looking for a finished solution or you want to integrate it with your own design ?
-- Michelle.
IAkin
Hello Michelle,
Thanks for your reply. We have commercial dishwashers we use already and deploy to client sites like hotels for example. I would like to integrate the IoT chip into the machines to monitor them remotely and we don't have to travel long distances just to investigate an issue on the machine. The IoT device should be able to help us monitor temperatures and some more statistics on the machine like I wrote above in my first post. I want to know if its doable, and how to do it/procedures.
What are the options you have when you mention 'finished solution'? I have seen a lot of finished IoT devices like AT&T's IoT starter kit and much more. Since my boss is a partner with Intel we figured we could use Intel's IoT.
Let me know your thoughts and solutions.
Regards, Igb
Michelle_C_Intel
Hi Igb
Unfortunately, we do not have an off-the-shelf solution that you could use.
Generally we work with users on their own design -- or advise on a third party to work with if they do not have their own design team.
The kits we provide a Developer Kits i.e we do have a C1000 Evaluation Kit - https://software.intel.com/en-us/iot/hardware/c1000 Intel® Quark™ SE Microcontroller C1000 Evaluation Kit | IoT | Intel® Software
-- Michelle.
