Intel® Makers
9881 Discussions
intel Galileo GEN1 fails to boot from ConnectAnyThing SD card
yyehe
I have intel Galileo GEN1 and I trying to install SD image Version v0.2.1: 2014.04.22 and it fails to boot from SD card
Galileo Firmware is updated to the latest version (1.04)
Any ideas how can I boot into ConnectAnyThing?@
Community Manager
Hi yeheskel,
I recommend you to check the following site where there is all the information about ConnectAnyThing:http://https://github.com/IntelOpenDesign/ConnectAnyThing https://github.com/IntelOpenDesign/ConnectAnyThing. There is a complete guide about setting ConnectAnyThing up in the following site: https://github.com/IntelOpenDesign/ConnectAnyThing/wiki/How-To-Set-Up-Connect-AnyThing https://github.com/IntelOpenDesign/ConnectAnyThing/wiki/How-To-Set-Up-Connect-AnyThing. Note that there are some comments regarding Galileo Gen1. I recommend you to check them.
The following site might be helpful too: https://github.com/IntelOpenDesign/ConnectAnyThing/releases https://github.com/IntelOpenDesign/ConnectAnyThing/releases. You will find some additional comments about the versions of ConnectAnyThing.
The ConnectAnyThing project hasn't had updates since a year ago. If you have questions about it, I recommend you to contact the team in charge of it. You can find their contact information in the following site: https://github.com/IntelOpenDesign/ConnectAnyThing# the-team https://github.com/IntelOpenDesign/ConnectAnyThing# the-team
Diego
Community Manager
Hi yeheskel,
Diego
