Community
cancel
Showing results for
Search instead for
Did you mean:
CSava1
intel edison + arduino board analog readings
Jump to solution
Hello guys,
I wanted to do some analog readings with my Edison and found out that it's reading some values without any inputs in analog pins.
If I read one pin at a time I get 120-123 value in serial monitor.
If I read all the pins at the same time I get 108899589554578 (code below).
int value;
int value1;
int value2;
int value3;
int value4;
int value5;
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
value = analogRead(A0);
value1 = analogRead(A1);
value2 = analogRead(A2);
value3 = analogRead(A3);
value4 = analogRead(A4);
value5 = analogRead(A5);
void loop() {
// put your main code here, to run repeatedly:
Serial.print(value);
Serial.print(value1);
Serial.print(value2);
Serial.print(value3);
Serial.print(value4);
Serial.print(value5);
Serial.println(" ");
any idea why it's showing values without any analog input in any analog pin?
thanks
Pablo_M_Intel
Hi Cristi_Sava,
It seems like your inputs are undefined. By adding a signal to read or a pull up/down resistor I believe this behavior should stop. Have you tried adding a signal to any of the pins? The large number that you're getting is just the read from each of the channels put together. I would suggest you to try with a 'real' signal, so we can see what you get.
PabloM_Intel
Pablo_M_Intel
Hi Cristi_Sava,
PabloM_Intel
