Intel® Makers
9873 Discussions
intel edison error:-ioctl(VIDIOC_STREAMON): Invalid argument
Community Manager
Hello everyone,
I'm trying to get video streaming over http using ffmpeg on my intel edison.
i'm using Logitech C270 camera as input.
I'm getting video stream without any problem for first few trials but
after some unspecific numbers of trials, when I'm running the command to stream, it gives the error.
Here is my log:-
//below is ffmpeg command & log:-
root@edison:~/testing# ffmpeg -vcodec mjpeg -f video4linux2 -i /dev/video0 http://192.168.0.171:8090/feed1.ffm http://192.168.0.171:8090/feed1.ffm
ffmpeg version 2.8.2-static http://johnvansickle.com/ffmpeg/ http://johnvansickle.com/ffmpeg/
Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 5.2.1 (Debian 5.2.1-23) 20151028
configuration: --enable-gpl --enable-version3 --disable-shared --disable-debug --enable-runtime-cpudetect --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --cc=gcc
libavutil 54. 31.100 / 54. 31.100
libavcodec 56. 60.100 / 56. 60.100
libavformat 56. 40.101 / 56. 40.101
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 40.101 / 5. 40.101
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.101 / 1. 2.101
libpostproc 53. 3.100 / 53. 3.100
[video4linux2,v4l2 @ 0xa5d3f80] ioctl(VIDIOC_STREAMON): Invalid argument
/dev/video0: Invalid argument
when I searched on internet, I found the following link which has some useful information about the error. Here is thehttp://linuxtv.org/downloads/v4l-dvb-apis/vidioc-streamon.html Link
conclusion of this link is something like:- > buffer is still occupied
So what can I do to resolve this error ??
Are there any commands or tasks that I need to perform ?
Thank you
Pedro_M_Intel
Hello mailto:falak.desai@yahoo.com falak.desai@yahoo.com,
Have you checked https://github.com/drejkim/edi-cam drejkim/edi-cam · GitHub? That project might be what you're looking for. I just tested it and it worked just fine, the only difference that I had to make from the guide is that instead of using MyEdison.local, I used the Edison's IP address both on the index.html file and on the browser's window. But apart from that, the guide is very simple and easy to follow.
It's definitely worth checking it out, why don't you try it?
Peter.
Community Manager
Hi Peter,
yes I know this repository, but I've already got the streaming which too works fine except for this buffer error.
So I'm looking for that solution.
Is there a hardware problem, or software that I have no idea about.
Falak
MPapi
Falak,
If you do a 'dmesg | tail' is there anything of interest in there? It would seem that the camera is either "dropped" or disconnected.
Mario
Pedro_M_Intel
I would also like to see dmesg shows anything of interest. Also, could you let us know how the error comes up? A screenshot of the error message would be of help. How did you install ffmpeg?
Peter.
Carlos_M_Intel
Hi Falak,
Do you have updates on this?
Could you provide the output of dmesg | tail and the error message?
Charlie
CJeng
I have the same issue, when I use this command
ffmpeg -s 640x480 -f video4linux2 -i /dev/video0 -f mpeg1video -b:v 800k -r 30 http://127.0.0.1:8082/ http://127.0.0.1:8082/
The error msg
ffmpeg version N-79255-g6d7f566-static http://johnvansickle.com/ffmpeg/ http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers
built with gcc 5.3.1 (Debian 5.3.1-13) 20160323
configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --enable-libzimg --cc=gcc
libavutil 55. 20.100 / 55. 20.100
libavcodec 57. 34.100 / 57. 34.100
libavformat 57. 30.100 / 57. 30.100
libavdevice 57. 0.101 / 57. 0.101
libavfilter 6. 40.102 / 6. 40.102
libswscale 4. 1.100 / 4. 1.100
libswresample 2. 0.101 / 2. 0.101
libpostproc 54. 0.100 / 54. 0.100
[video4linux2,v4l2 @ 0xc0c5400] ioctl(VIDIOC_STREAMON): Invalid argument
This is my dmesg|tail
root@edison:~# dmesg | tail
[ 17.808851] snd_intel_sst: Stop for str 1 pipe 0x90
[ 17.809364] snd_intel_sst: Free for str 1 pipe 0x90
[ 17.811738] snd_intel_sst: runtime_idle called
[ 19.803911] snd_intel_sst: runtime_suspend called
[ 134.708926] dwc3-host dwc3-host.2: Signal while waiting for configure endpoint command
[ 134.719482] usb 1-1: Not enough bandwidth for altsetting 0
[ 139.139584] dwc3-host dwc3-host.2: xHCI xhci_drop_endpoint called with disabled ep f54e1cc0
[ 139.139617] dwc3-host dwc3-host.2: Trying to add endpoint 0x81 without dropping it.
[ 139.139646] usb 1-1: Not enough bandwidth for altsetting 11
[ 139.139672] dwc3-host dwc3-host.2: xHCI xhci_drop_endpoint called with disabled ep f54e1cc0
It won't error when I press q or ctrl+c and sys prints
Exiting normally, received signal 2.
In other words, when the process end without this msg, next time you run ffmpeg, shows error.
When the error happened, I need replug the usb or reboot the system.
When I use
ffmpeg -f video4linux2 -i /dev/video0 -f flv rtmp://127.0.0.1
, it doesn't have this kind error.
