I am using intel edison kit for Arduino and I am using intel XDK as a development tool. I want to make a server of edison that can access anytime and anywhere using wifi wireless router. So I opened the 4242 port using intel XDK. However, in the internal network, it is possible to connect to port 4242, but it is impossible to connect to the external network. You can only connect to the port providing intel device information from the external network, and you can not connect to port 4242.
Hi jun,
Thanks for reaching out.
Could you please let me know which Edison image you are using? Also, if you are running any XDK Web server sample application. I'll be waiting for your response.
-Yermi A.
Hello Yermi A,
thank you for your reply.
I am using edison-image-from-src-package-ww25.5-15 image.
When you assign an IP address to edison, you can access it in the same network as edison.
However, connection from external network is impossible.
We would appreciate any help on how to connect from an external network.
Hi Jun,
This has to be done by configuring port-forwarding in the router. There are several tutorials about this and Arduino. That information can be used as well with Edison. This is a brief explanation about what this is about: https://startingelectronics.org/tutorials/arduino/connecting-arduino-to-internet/ https://startingelectronics.org/tutorials/arduino/connecting-arduino-to-internet/.
Additionally, you can take a look at this other links for more information:
- http://www.instructables.com/id/How-to-Connect-your-Arduino-to-the-Internet-as-a-W/ How To: Connect Your Arduino to the Internet As a Web Server
- http://www.the-diy-life.com/accessing-an-arduino-over-the-internet/ Accessing An Arduino Over The Internet
- https://www.howtogeek.com/66214/how-to-forward-ports-on-your-router/ How to Forward Ports on Your Router
Hope this information helps.
-Yermi A.
Hello Yermi A,
First, I would like to thank you for your help.
I read a website with links.
After that, I connected to the server that manages the wifi router,set up DDNS, and then port forwarded.
In the end, the problem was resolved neatly.
I hope you have a good day
-Junki
