Community
cancel
Showing results for
Search instead for
Did you mean:
ACyri1
intel edison
Jump to solution
Can I use AVR ide for programming an intel edison board?? Which is the best IDE can be used for windows??
Matthias_H_Intel
If you use an existing Eclipse IDE you'd have to run through quite some configuration & installation on your own.
I'd recommend using one of the existing solutions (e.g. Intel(R) IoT devkit Eclipse IDE) starting with e.g.
Matthias_H_Intel
