Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
intel edison
I want to rilun 2 motors using intel edison mini breakout board. ....which should be controlled by my Android phone?
Highlighted
Re: intel edison
go for it - or was there a question?
Highlighted
Valued Contributor I
Re: intel edison
Yes
Highlighted
Re: intel edison
I dono how to code. ..any help?
Highlighted
Re: intel edison
Question. ....i dono coding!!
Highlighted
Re: intel edison
I'd suggest you to start with the basics, play with the Arduino IDE a while before proceed to do a much more complicated project like this, so I'd suggest you to start here: http://arduino.cc/en/pmwiki.php?n=Tutorial/HomePage Arduino - Learn the basics. Read through the Arduino commandsand start experimenting with them, what you want to do is possible but needs a lot of practice. Read the sketches included in the IDE and try to understand how they work, then modify them to make your own, and step by step you'll get there.
Peter.
Highlighted
Re: intel edison
Dear vivek,
http://www.catb.org/~esr/faqs/smart-questions.html http://www.catb.org/~esr/faqs/smart-questions.html
(please read the entire link above *very* carefully, then come back and rephrase your question)
marcus
