Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
New Contributor III
intel galileo gen 2 logilink webcam issue
Jump to solution
Basically i am using logilink webcam.when i connect it to the board i dont see any ./dev message.
also i have checked the uvcdriver is installed as well.
can u guide me step wise what to do to take make webcam take a picture using linux command
i have also tried fswebam it gives this error
Opening /dev/video0...
stat: No such file or directory
Annu
Tags (1)
Accepted Solutions
Highlighted
Re: intel galileo gen 2 logilink webcam issue
Jump to solution
Hi @annu_shah,
I'd suggest you to check this /thread/56024 post I think it might help you specially last rgb's guide in the last message . Please check it out and let me know if it helps.
JPMontero_Intel
Highlighted
1 View
Jump to solution
Hi @annu_shah,
JPMontero_Intel
Highlighted
New Contributor III
Jump to solution
yes thank you the fswebcam command is working now
but i am unable to open it using linux command
Highlighted
New Contributor III
Jump to solution
i have used these command to open the jpg file :-
sh: xdg-open: command not found
sh: gnome-open: command not found
sh: eog: command not found
sh-4.2#
Highlighted
Jump to solution
Hi annu_shah,
You are using IoT image, right? Have you tried installing xdg-open? I think the other commands could be more difficult to make them work because Yocto does not include a desktop environment.
JPMontero_Intel
Highlighted
New Contributor III
Jump to solution
no am using the yocto 1.4.2,the sd card image.
i tried using opkg install xdg-open
Highlighted
Valued Contributor I
Jump to solution
Hi Annu_shah
Unless you have a a graphic display connected to your Galileo, you won't be able to see the images directly.The best was I know to view images is install FileZilla client https://filezilla-project.org/ https://filezilla-project.org/ After you install it, go to file/site manager. Create a new site with the IP address of your Galileo, leave port blank, change from FTP to SFTP,, change login type to interactive, enter root as user and click on connect. You can then browse to where you have the image, right click on it and click on view/edit to see the image.
rgb
Highlighted
New Contributor III
Jump to solution
Intel Galileo Gen 2 Eurobot videos :-
https://plus.google.com/u/0/116374697724603787600/videos annu shah - Videos - Google+
