hi, when I use Accelstepper library to do the stepper motor, the motor does no any response. but I can use this library in the Arduino UNO. why the intel galileo gen2 board cannot uppot library.anyone has some ideals and some new library...thanks so much.
Hello celia_0614,
There are Arduino libraries that have been written based on the Arduino board architecture. Those libraries won't work for Galileo. Even though they compile on the Arduino IDE, their architecture is different, so they are not compatible with Galileo. My suggestion for you would be to write your own library based on the stepper's functionality. You could base your new library on the AccelStepper library for Arduino UNO.
Diego.
Hello celia_0614,
Diego.
EDIT:
When charging the accelerometer library mma7361 and compiling generates the following error.
C: \ Users \ Antonio \ Documents \ Arduino \ libraries \ AcceleroMMA7361 \ AcceleroMMA7361.cpp: 406: 44: error: 'square' was not declared in this scope
Other standard libraries compile normally. servo.h, ethernet.h, etc ...
When I switch to GalileoGen2 board to Arduino, the compilation does not generate errors. Could anyone help?
Installed intel Galileo IDE 1.6.0 64-bit Windows
Hello Galileo_BR,
I've just posted a suggestion in your other thread, please check it:
Diego.
