hello
i am using edison-src-ww25.5-15.tgz and make image stops at .../meta-intel-iot-middleware/recipes-devtools/iotkit-comm-c/iotkit-comm-c_0.1.1.bb as intel deleted the entire content from GitHub (git://github.com/intel-iot-devkit/iotkit-comm-c.git)
1) thank you intel to create unnecessary troubles
2) how to fix that issue?
thank you
Andre
Hi Andre,
Thanks for contacting us!
We're sorry that you are getting these issues, we have checked for the iotkit-comm-c, and absolutely, that was deleted, please let us investigate about it and as soon as we find useful information we'll let you know.
We'll really appreciate your patience during the meantime.
-Yermi
Do you have an update. The repo is still not found.
regards
Arun
Hi Arun,
Thank you very much for your patience.
The iotkit-comm-c was removed from Github since it was mainly used to send data to IoT Analytics dashboard and it has been discontinued, as you can see in this link: /thread/107871 https://communities.intel.com/thread/107871, we would like to let you know you need to remove the recipe from the image, the image file is located in /edison-src/poky/meta-intel-edison-distro/recipes-core/images/edison-image.bb. The following lines need to be commented/removed:
IMAGE_INSTALL += "iotkit-comm-js"
IMAGE_INSTALL += "iotkit-comm-c-dev"
We apologize for the inconvenience. Currently, we're working on it.
-Yermi
Any idea when it will be available again?
Or If we could get old version to build our image?
Thank you.
Hi Paul,
IoT Analytics has been taken offline, please visit the https://software.intel.com/en-us/iot/hardware/edison The Intel® Edison Module | IoT | Intel® Software for alternative solutions. Old versions include the iotkit-comm-c recipe, so you should remove it in order to build the image as it is mentioned above.
-Yermi
We would like to let you know that this issue is in consideration for a future release of Edison software.
Yermi
