Intel® Makers
9874 Discussions
it didn't recognize me the intel Edison COM port. Help!!!
PVald1
Hi, I am a student and I had problems the last two days with Intel Edison , it didn't recognize me the intel Edison COM port. I took the Intel and seems to be formatting. I had been trying Yocto installing , reinstalling the firmware but I found full installation errors , I would greatly appreciate If you could help with to resolve problem. Many thanks.
Community Manager
Hello pauloocv,
It seems that your Edison might have had a software issue at its OS level. I suggest you to try to recover your board with either the Flash Tool Lite method or the flashall method. You can find them in:
Flash Tool Lite:
https://software.intel.com/en-us/articles/flash-tool-lite-user-manual
Flashall:
https://communities.intel.com/docs/DOC-25154 https://communities.intel.com/docs/DOC-25154
If those methods do not work, then i'd suggest you to use the Flashall.sh and pre-built xFSTK method which can be found in:
https://communities.intel.com/message/257171# 257171 https://communities.intel.com/message/257171# 257171
Let me know if you are able to use your board after trying these methods, I'd be glad to help if otherwise.
-Peter.
Community Manager
Do you have any updates on this? Were you able to recover your board?
-Peter.
