Community
cancel
Showing results for
Search instead for
Did you mean:
llaur1
iwlwifi: 5300: wifi random disconnect with Failed to send nullfunc intel galileo gen 1
I have 5 intel Galileo gen1with distribution yocto linux kernel 3.19.8 and Intel NIC 5300 agn. Boards send ping to a AP with interval 0.05s. Randomically one board disonnect and often reconnect wifi network with this log:
Dec 07 08:43:51 quark31 kernel: wlp1s0: detected beacon loss from AP (missed 7 beacons) - probing
Dec 07 08:43:56 quark31 kernel: wlp1s0: tx session timer expired on 14:cc:20:98:00:28 tid 0
Dec 07 08:43:56 quark31 kernel: wlp1s0: Tx BA session stop requested for 14:cc:20:98:00:28 tid 0
Dec 07 08:44:21 quark31 kernel: wlp1s0: Failed to send nullfunc to AP 14:cc:20:98:00:28 after 30000ms, disconnecting
Dec 07 08:44:21 quark31 kernel: wlp1s0: Rx BA session stop requested for 14:cc:20:98:00:28 tid 0 recipient reason: 36
Dec 07 08:44:21 quark31 kernel: wlp1s0: Rx BA session stop requested for 14:cc:20:98:00:28 tid 6 recipient reason: 36
Dec 07 08:44:21 quark31 kernel: wlp1s0: moving STA 14:cc:20:98:00:28 to state 3
Dec 07 08:44:21 quark31 kernel: wlp1s0: moving STA 14:cc:20:98:00:28 to state 2
Dec 07 08:44:21 quark31 kernel: wlp1s0: moving STA 14:cc:20:98:00:28 to state 1
Dec 07 08:44:21 quark31 kernel: wlp1s0: Removed STA 14:cc:20:98:00:28
Dec 07 08:44:21 quark31 kernel: wlp1s0: Destroyed STA 14:cc:20:98:00:28
Dec 07 08:44:22 quark31 kernel: iwlwifi 0000:01:00.0: txq_id mismatch: 11 0
Dec 07 08:44:22 quark31 kernel: cfg80211: Calling CRDA to update world regulatory domain
Dec 07 08:44:21 quark31 connmand[269]: wlp1s0 {RX} 14859 packets 1604686 bytes
Dec 07 08:44:21 quark31 connmand[269]: wlp1s0 {TX} 14143 packets 2070277 bytes
Dec 07 08:44:21 quark31 connmand[269]: wlp1s0 {update} flags 36867
Dec 07 08:44:22 quark31 connmand[269]: wlp1s0 {newlink} index 3 address 00:21:6A:24:D5:74 mtu 1500
Dec 07 08:44:22 quark31 connmand[269]: wlp1s0 {newlink} index 3 operstate 2
Dec 07 08:44:22 quark31 connmand[269]: wlp1s0 {del} address 192.168.0.110/24 label wlp1s0
Dec 07 08:44:22 quark31 connmand[269]: wlp1s0 {del} route 192.168.0.0 gw 0.0.0.0 scope 253
Dec 07 08:44:21 quark31 systemd-timesyncd[224]: No network connectivity, watching for changes.
Dec 07 08:45:03 quark31 sshd[288]: Timeout, client not responding.
Dec 07 08:45:03 quark31 sshd[288]: syslogin_perform_logout: logout() returned an error
is there a patch or fix to prevent this problem?
Community Manager
Hi manosplace92,
Thank you for contacting us.
The first thing that comes to mind as to why your board keeps disconnecting is because it doesn't has the proper firmware for you wireless card. Take a look at https://wireless.wiki.kernel.org/en/users/Drivers/iwlwifi https://wireless.wiki.kernel.org/en/users/Drivers/iwlwifi and download the firmware for your device. You can follow http://www.malinov.com/Home/sergey-s-blog/intelgalileo-addingwifi http://www.malinov.com/Home/sergey-s-blog/intelgalileo-addingwifi for the steps to install the firmware on your Galileo.
Let us know your results after following these steps.
-Sergio
Community Manager
Hi manosplace92,
Do you still need assistance with this case? Did you try our previous suggestion?
-Sergio
llaur1
I can't change the firmware but it is right for the nic..... but i have found a patch that mitigate the problem
Community Manager
Hi manosplace92,
Thank you for letting us know you managed to find a solution to your problem. We encourage you to share your findings with the community. Other users will definitively benefit from them.
-Sergio
