Intel® Makers
9872 Discussions
kernel panic with gadgetfs
FATA
Hi All
I want to test gadgetfs on galelio gen1 board.For which i am followwing steps mentioned on the link http://blackfin.uclinux.org/doku.php?id=linux-kernel:usb-gadget:fs linux-kernel:usb-gadget:fs [Analog Devices Open Source| Mixed-signal and Digital Signal Processing ICs]
I am able to perform below steps
root:/dev> modprobe gadgetfs
root:/dev> mkdir /dev/gadget
root:/dev> mount -t gadgetfs gadgetfs /dev/gadget
root:/dev> ls /dev/gadget/ -l
-rw------- 1 root root 0 Jan 1 04:29 pch_udc.
But when i am doing root:~> gadgetfs-test -r "1.3" -v.
I observe kernel panic.Below are the logs.
root@quark:/media/mmcblk0p1# ./gadgetfs-test -r "1.3" -v
[ 91.884169] gadgetfs: bound to pch_udc driver
[ 91.894735] gadgetfs: suspended from state 2
/dev/gadget/pch_udc ep0 configured
serial="1.3"
** Mon Jan 1 00:01:52 2001
SUSPEND
[ 92.142841] gadgetfs: connected
CONNECT high spe
[ 92.146943] BUG: unable to handle kernel paging request at d27d35ed
[ 92.152799] IP: [] ep0_complete+0x7d/0xc0 [gadgetfs]
[ 92.152799] *pdpt = 000000000148f001 *pde = 000000000002b067 *pte = 000000000e333061
[ 92.152799] Oops: 0003 [# 1]
[ 92.152799] Modules linked in: gadgetfs ad7298 industrialio_triggered_buffer kfifo_buf industrialio cy8c9540a usbhid usb_storage spidev spi_]
[ 92.152799] Pid: 243, comm: gadgetfs-test Not tainted 3.8.7-yocto-standard # 7 Intel Corp. QUARK/Galileo
[ 92.152799] EIP: 0060:[] EFLAGS: 00010046 CPU: 0
[ 92.152799] EIP is at ep0_complete+0x7d/0xc0 [gadgetfs]
[ 92.152799] EAX: 00000008 EBX: d27d35a0 ECX: 00000000 EDX: 00000003
[ 92.152799] ESI: c1e9fba0 EDI: c1e8117c EBP: c0093f24 ESP: c0093f0c
[ 92.152799] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
[ 92.152799] CR0: 8005003b CR2: d27d35ed CR3: 01f11000 CR4: 00100030
[ 92.152799] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[ 92.152799] DR6: ffff0ff0 DR7: 00000400
[ 92.152799] Process gadgetfs-test (pid: 243, ti=c0092000 task=c1d9f440 task.ti=c1ca6000)
[ 92.152799] Stack:
[ 92.152799] 000000ac 00000004 00000096 c1e9fba0 c1e8117c 00000000 c0093f44 d2727ac9
[ 92.152799] 000000ac d2727c6c 00000001 c1e8117c c1e9fbe0 c1e811b8 c0093f6c d2728724
[ 92.152799] c1e8117c 00000000 c0093f6c d2727df1 c1e81000 00000400 c1e8117c c1e81000
[ 92.152799] Call Trace:
[ 92.152799] [] complete_req+0xd9/0x190 [pch_udc]
[ 92.152799] [] ? pch_udc_ep_clear_nak+0x1c/0x130 [pch_udc]
[ 92.152799] [] pch_udc_complete_transfer+0x64/0x150 [pch_udc]
[ 92.152799] [] ? pch_udc_postsvc_epinters+0x71/0x80 [pch_udc]
[ 92.152799] [] pch_udc_isr+0xf9a/0x111d [pch_udc]
[ 92.152799] [] ? dw8250_handle_irq+0x1a/0x60
[ 92.152799] [] handle_irq_event_percpu+0x20/0x120
[ 92.152799] [] ? printk+0x38/0x3a
[ 92.152799] [] ? handle_simple_irq+0x60/0x60
[ 92.152799] [] handle_irq_event+0x1c/0x30
[ 92.152799] [] handle_edge_irq+0x56/0xf0
[ 92.152799]
[ 92.152799] [] ? do_IRQ+0x34/0xa0
[ 92.152799] [] ? common_interrupt+0x2c/0x31
[ 92.152799] [] ? 0xd27d2fff
[ 92.152799] [] ? vsscanf+0x2c0/0x5f0
[ 92.152799] [] ? do_sys_poll+0x281/0x480
[ 92.152799] [] ? submit_bio+0x45/0x100
[ 92.152799] [] ? __enqueue_entity+0x65/0x70
[ 92.152799] [] ? enqueue_task_fair+0x159/0x220
[ 92.152799] [] ? check_preempt_curr+0x6c/0x80
[ 92.152799] [] ? default_wake_function+0xb/0x10
[ 92.152799] [] ? __wake_up_common+0x3f/0x70
[ 92.152799] [] ? __wake_up_locked+0x1a/0x20
[ 92.152799] [] ? poll_initwait+0x40/0x40
[ 92.152799] [] ? poll_select_copy_remaining+0x100/0x100
[ 92.152799] [] ? kmap_atomic_prot+0x3e/0xd0</...
Sergio_A_Intel
Did you do any additional changes to the kernel when you enabled gadgetfs?
Were these the changes in kernel configuration:
CONFIG_USB_GADGETFS=m
Have you tried changing these options to "y" instead of "m"?
Sergio
Carlos_M_Intel
Hi farazata,
Do you have updates in this? Have you tried with Sergio's suggestion?
Charlie
FATA
yes i tried with that still my issue is not yet fixed
Sergio_A_Intel
Gadgetfs was not tested or validated on the Intel Galileo. It is possible to make it work on Galileo but it will need kernel debugging and patches.
Sergio
