Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
ksize.py & dirsize.py for  Yocto on Galileo
Hi
I followed : http://www.malinov.com/Home/sergey-s-blog/intelgalileo-buildinglinuximage Intel Galileo - Building Linux Image - Malinov Family Web Presence
to build full image of Yocto on Galileo. I found there are not ksize.py & dirsize.py. So I found them on internet as attached files.
When I run ksize.py under yocto_build directory, the result is as following:
[leizhou@localhost yocto_build]$ ksize.py > ksize.log
[leizhou@localhost yocto_build]$ cat ksize.log
Linux Kernel total | text data bss
vmlinux 0 | 0 0 0
sum 0 | 0 0 0
delta 0 | 0 0 0
And when I run dirsize.py under /meta-clanton_v0.7.5/yocto_build/tmp/deploy/images/meta-clanton_v0.7.5/yocto_build/tmp/deploy/images directory, the result is:
[leizhou@localhost images]$ dirsize.py 100000 > dirsize-100k.log
[leizhou@localhost images]$ cat dirsize-100k.log
636093135 .
314572800 ./image-full-clanton-20140429011544.rootfs.ext3
314572800 ./image-full-clanton-20140429155141.rootfs.ext3
2113920 ./bzImage--3.8-r0-clanton-20140429011544.bin
1432459 ./core-image-minimal-initramfs-clanton-20140429155141.rootfs.cpio.gz
1432407 ./core-image-minimal-initramfs-clanton-20140429011544.rootfs.cpio.gz
1322167 ./modules--3.8-r0-clanton-20140429011544.tgz
367104 ./bootia32.efi
278383 ./grub.efi
Displayed 636092040/636093135 bytes (100.00%)
It seems to be a wrong way to build the tiny system. Could you tell me what is the problem?
Thanks so much.
Lei
Tags (1)
Highlighted
Greetings LeiZhou
It looks like there is a bug for those python scripts and they may not work correctly on Yocto, take a look at this link https://www.yoctoproject.org/bug/bug-5388-ksizepy-and-dirsizepy-should-exists-scripts-directory https://www.yoctoproject.org/bug/bug-5388-ksizepy-and-dirsizepy-should-exists-scripts-directory. We recommend you to follow up on this matter on the Yocto forum.
JPMontero_Intel
