I am trying to use the praat tool on my Intel Edison, but the only library that is giving me is a problem is the libstdc++.so.6. The exact problem is that the tool requires a newer version of the library, specifically /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.21' not found. Is there any way that I can install this version specifically. When I do strings to check which versions are available, the only one that seems to be missing is 3.4.21. These are the versions that are available.
GLIBCXX_3.4
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
GLIBCXX_3.4.18
GLIBCXX_3.4.19
GLIBCXX_3.4.20
GLIBC_2.3
GLIBC_2.0
GLIBC_2.1
GLIBC_2.17
GLIBC_2.1.3
GLIBC_2.3.2
GLIBC_2.2</...
Currently I looked up what gcc is on the Edison and the 4.9.1 is what is up to date with opkg. Although when I look on the gcc site, the newest one is 5.3. How can I install the newest version of gcc on the Edison ?
I would like to know more information about this in order to try to replicate the same environment.
How are you installing the Praat Tool?
Did you install libstdc++6 with opkg from the AlexT's repo?
In order to install this GCC version, I suggest you to look at this: http://www.linuxfromscratch.org/blfs/view/svn/general/gcc.html GCC-5.3.0
Charlie
The Praat tool I downloaded directly form the praat website and sftp'd it to the Edison. No installation per say required. http://www.fon.hum.uva.nl/praat/ Praat: doing Phonetics by Computer
yes I believe I did install it with AlexT repo. But I thought the library comes with GCC. I have looked at different examples, it seems that the version of the libstdc++6 only comes with newer version of gcc which opkg says the up to date now is 4.9.1, however that is not the case.
Admir M.
Hi Admir,
Do you have updates on this?
I would like to know if you tried to install a newer gcc version.
Also, are you using a Linux machine? Did you run strings on the libstdc++6 on the PC? If you have on your PC the .so with GLIBCXX that you need you can try to add the module (and replace it) in /usr/lib of your board.
Please let me know if you have some updates on this
Charlie
Hi CMata_Intel,
I am currently running the make on the Edison. It will take a while since when I ran the first time it ran but when I did make install I didn't have any space left. I am making it again but in specified location where I will have enough space to make install. gcc 5.3 does come with a newer libstdc++6 so the newer version that I want is included. But if you can do that, how could one send the module of the newer version to the edison? I checked the version of newer version on ubuntu.
How can I access the version of the library individually?
Hi Admir,
I tried it by installing libstdc++6 using a Ubuntu machine then I send the .so.6 to the Edison but this didn't work due to a lot of conflicts between the gcc versions and builds.
Were you able to run make install successfully?
Did you re-size the partitions of the image?
Charlie
Hi CMata_Intel,
I was able to install gcc 5.3 on the edison successfully. I am now looking to point the libstd to the newer version of libstd that was installed with the newer gcc. I was able to install gcc on a local folder that I made in home which I increased the size with an sd by using fstab.
I hope this will work with the praat tool since I now have all the libraries that I need.
Admir
