Community
cancel
Showing results for
Search instead for
Did you mean:
jnich3
lighttpd, fast-cgi and php: I'm close, but not there...
Ok, using AlexT repository I have installed lighttpd and php-cgi and php.
lighttpd installation worked in the sense that I could get the "It works" default page to load in a browser, using a minimal lighttpd.conf file.
It would appear that installation of PHP stuff has succeeded. i.e.
root@edison1:/etc# php-cgi -v
PHP 5.5.26 (cgi-fcgi) (built: Jul 29 2015 20:33:01)
Copyright (c) 1997-2015 The PHP Group
Zend Engine v2.5.0, Copyright (c) 1998-2015 Zend Technologies
however,
root@edison1:/etc# php -v
-sh: php: command not found
but then again, (I assume some path issue above?)
root@edison1:/etc# opkg install php
Package php (5.5.26-r0) installed in root is up to date.
If I now try to startup lighttpd I get:
root@edison1:/etc# lighttpd -D -f lighttpd.conf
2015-09-26 13:26:13: (/edison_dev/yocto/ww25/out/linux64/build/tmp/work/core2-32-poky-linux/lighttpd/1.4.35-r1/lighttpd-1.4.35/src/plugin.c.169) dlopen() failed for: /usr/lib/mod_fastcgi.so /usr/lib/mod_fastcgi.so: cannot open shared object file: No such file or directory
2015-09-26 13:26:13: (/edison_dev/yocto/ww25/out/linux64/build/tmp/work/core2-32-poky-linux/lighttpd/1.4.35-r1/lighttpd-1.4.35/src/server.c.679) loading plugins finally failed
root@edison1:/etc#
any help appreciated. Here is my current lighttpd.conf file:
server.modules = (
"mod_access",
"mod_fastcgi",
"mod_accesslog" )
server.document-root = "/www/pages/"
server.port = 80
mimetype.assign = (
".html" => "text/html",
".txt" => "text/plain",
".jpg" => "image/jpeg",
".png" => "image/png"
)failed for: /usr/lib/mod_fastcgi.so
# files to check for if .../ is requested
index-file.names = ( "index.php", "index.html",
"index.htm", "default.htm" )
# fastcgi module
# read fastcgi.txt for more info
# for PHP don't forget to set cgi.fix_pathinfo = 1 in the php.ini
fastcgi.server = ( ".php" =>
( "localhost" =>
"socket" => "/tmp/php-fastcgi.socket",
"bin-path" => "/usr/bin/php-cgi"
Matthias_H_Intel
  • php-cgi should be fine, shouldn't it?
  • /usr/lib/mod_fastcgi.so /usr/lib/mod_fastcgi.so: cannot open shared object file: No such file or directory - check your fastcgi installation
jnich3
I'm not sure how to check the fastcgi installation.I assumed from the messages above that it was installed ok as in: PHP 5.5.26 (cgi-fcgi)
I don't know how else to install it, or start it up up, other than using the config file, which won't run?
could you expand a little
thanks
Matthias_H_Intel
you would have to install the mod_fastcgi for lighttpd - there should be an extra package. Check AlexT's repo
jnich3
yes. found it. installed it. success!
thanks
Matthias_H_Intel
so pls mark as answered
