Intel® Makers
9872 Discussions
mcu api - "connection to 192.168.2.15 failed"
ddor
hello,
i'm quite new to Edison, and the mcu api in particular.
i'm trying to create an mcu api project, and i've walked through the entire official tutorial, and yet, is still can't manage to "download"
my project to the board, as i get a "connection to 192.168.2.15 failed" error everytime..
what am i missing ?
thanks for the help,
Dor
Diego_V_Intel
Hi dorlX,
That issue might be caused by the IP address used by your Edison. You need to access the Edison's console and run the following command: configure_edison --showWiFiIP. This command will show you what IP address your Edison has. That's the IP address you should use in the MCU SDK.
The IP address 192.168.2.15 is the default IP address, and it has be changed if your Edison has another one. Please check the following guide: https://software.intel.com/en-us/node/545144 Creating, building, and working with MCU projects | Intel® Developer Zone. In the section "Connecting Eclipse to a different board" you will find the instructions to change the IP address in the MCU SDK.
Diego
Diego_V_Intel
Hi dorlX,
Diego
ddor
