Intel® Makers
9881 Discussions
modprobe probem:unknown symbol
YMeng3
Hello guys:
I add a `udlfb` module into the edison-yocto image, according to the Kconfig:
config FB_UDL
tristate "Displaylink USB Framebuffer support"
depends on FB && USB
select FB_MODE_HELPERS
select FB_SYS_FILLRECT
select FB_SYS_COPYAREA
select FB_SYS_IMAGEBLIT
select FB_SYS_FOPS
select FB_DEFERRED_IO
---help---
This is a kernel framebuffer driver for DisplayLink USB devices.
Supports fbdev clients like xf86-video-fbdev, kdrive, fbi, and
mplayer -vo fbdev. Supports all USB 2.0 era DisplayLink devices.
To compile as a module, choose M here: the module name is udlfb.
But when I run `modprobe` on the edison board, it gives me :
I run
./udlfb.ko | grep depend
and it shows me that the module depends on fb_sys_fops,sysfillrect,syscopyarea,sysimgblt, and I have already run 'modprobe' one by one. What should I do ?
Community Manager
You said you ran modprobe on all the dependencies. Did you build these dependencies or you just added them to the image?
What other changes have you made to the kernel?
Sergio
