Community
cancel
Showing results for
Search instead for
Did you mean:
RCopp
mount /var/log to ram disk?
Jump to solution
hi guys
question: based on some thread i read about the RasperryPi, it was recommended to mount directories with frequently written files like log files to a ram disk
to prevent the flash from aging
is this something recommended for the edison as well?
best regards
a lill angel
Matthias_H_Intel
if you don't require persistent log files (i.e. analysis what happened the last boot) it's probably a good idea to send the data to ram.
See e.g. on the setting to do so
Matthias_H_Intel
