Community
cancel
Showing results for
Search instead for
Did you mean:
dherj
my sketch suddenly stop working
Jump to solution
Hi Mates
Currently i'm working with intel edison. I tried blink example from arduino ide, but somehow after 5-6 minute blink, it suddenly stopped and i don't know why.
Is anyone ever experienced this problem?
Juno
Community Manager
Hi dimasherjuno,
Could you let us know what image version you are running? If you access the Edison's console and run the following command: configure_edison --version or cat /etc/version, you will get the image version.
The issue you are reporting might be a known issue as described in the following thread: /message/388831# 388831 https://communities.intel.com/message/388831# 388831. The workaround for that issue is described in the following thread: /thread/77945 https://communities.intel.com/thread/77945. I recommend you to check it, it might fix the current issue you are facing.
Diego
Community Manager
Hi dimasherjuno,
Diego
