Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
myserial library for Gen2
Jump to solution
I'm looking to create another serial port on my Gen 2.
I can't use Serial2 as a shield I'm using uses pins 2 and 3.
Is there a myserial library for Gen2?
I found this one but it says that it can only be used for pins 2 and 3?
https://github.com/MakersTeam/Galileo/blob/master/Arduino-Examples/SoftwareSerial/SoftwareSerial_Gal... https://github.com/MakersTeam/Galileo/blob/master/Arduino-Examples/SoftwareSerial/SoftwareSerial_Gal...
Carlos_M_Intel
Hi conor100,
According to the available speeds in the pins, only the 2 and 3 can be used with this library.
In the SoftwareSerial.cpp you can comment the line assert(receivePin == 2 && transmitPin == 3); so you could try with other pins.
But in the meantime only with the pins 2 and 3.
Charlie
Carlos_M_Intel
Hi conor100,
Charlie
Community Manager
I have used a Sparkfun Go Between Shield https://www.sparkfun.com/products/11002 https://www.sparkfun.com/products/11002 to change the shield pin mappings on Arduino's before with great success. It lets you map pins from one pin to another. Maybe that could work if you don't find a software solution.
