Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
naui sources?
Jump to solution
The IoT ADT DevKit SD Card image for Galileo includes the lighttpd web server.
By default it serves up an HTML page with a few system statistics on it.
As far as I can see this default page (/www/pages/index.html) is auto-generated by naui (/init.d/naui) every 10 seconds or so.
Naui takes /usr/share/naui/index.html and populates the 'init' and 'variable' sections and saves it as /www/pages/index.html
The IoT ADT tutorial PDF says the source code for naui is on the SD Card image - but I cannot find it.
Does anyone know where it is?
Highlighted
Re: naui sources?
Jump to solution
Thank you :-)
