Intel® Makers
9872 Discussions
opencv 3.0 video error V4L/V4L2: VIDIOC_S_CROP
ian1
i'm trying to this with logitec c110 webcam and sparkfun edison base-board
but i skipped 2. Enabling UVC ( USB Video device Class ) by customizing the Linux Kernel ( optinal )
https://software.intel.com/en-us/articles/opencv-300-beta-ipp-tbb-enabled-on-yocto-with-intel-edison https://software.intel.com/en-us/articles/opencv-300-beta-ipp-tbb-enabled-on-yocto-with-intel-edison
environment is
Yocto linux 1.7.3
opencv 3.0.0
camera is ok, because i test this applicaion.(node.js & ffmpeg)
https://github.com/drejkim/edi-cam GitHub - drejkim/edi-cam: Video streaming on Intel Edison
but opencv 3.0.0 excuted by this code. error is appear
(for /home/ext is my sdcard directory. 8GB)
root@edison:/home/ext/opencv-3.0.0/samples/cpp# ./cpp-example-facedetect
VIDEOIO ERROR: V4L/V4L2: VIDIOC_S_CROP
facedetect.cpp like this.
# include "opencv2/opencv.hpp"
# include "opencv2/core/utility.hpp"
# include "opencv2/imgproc.hpp"
# include "opencv2/imgcodecs.hpp"
# include "opencv2/highgui.hpp"
using namespace cv;
using namespace std;
int main(int, char**)
VideoCapture cap(0); // open the default camera
if(!cap.isOpened()) // check if we succeeded
return -1;
return 0;
v4l2-ctl command is worked.
root@edison:/home/ext/opencv-3.0.0/samples/cpp# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 046d:0829 Logitech, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@edison:/home/ext/opencv-3.0.0/samples/cpp# v4l2-ctl -info
Video input set to 0 (Camera 1: ok)
root@edison:/home/ext/opencv-3.0.0/samples/cpp# v4l2-ctl --list-devices
Webcam C110 (usb-dwc3-host.2-1):
/dev/video0
root@edison:/home/ext/opencv-3.0.0/samples/cpp# v4l2-ctl --list-formats
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Name : YUV 4:2:2 (YUYV)
Index : 1
Pixel Format: 'MJPG' (compressed)
anyone help this error?
anyway v4l2 installed by opkg package manager.
root@edison:/home/ext/opencv-3.0.0/samples/cpp# opkg install v4l-utils
Package v4l-utils (1.0.1-r0) installed in root is up to date.
Community Manager
Hello insen.an,
In the document you posted above a newer version is mentioned: https://software.intel.com/en-us/articles/opencv-300-ipp-tbb-enabled-on-yocto-with-intel-edison https://software.intel.com/en-us/articles/opencv-300-ipp-tbb-enabled-on-yocto-with-intel-edison. Have you tried to follow this guide? If you haven't, I'd suggest you to try it and let us know what happens.
Peter.
Community Manager
Hello insen.an,
Peter.
