Intel® Makers
9872 Discussions
partition changing
aselv1
Download the http://software.intel.com/en-us/iot/hardware/edison/downloads Edison Linux source files.
where is the source file ??
where i have to done this process
Decompress the source file: tar xvf .
in bsp guide i run the first command but its showing me an error like
root@Sparky:~# sudo apt-get install build-essential git diffstat gawk chrpath texinfo libtool gcc-multilib
Reading package lists... Done
Building dependency tree
Reading state information... Done
chrpath is already the newest version.
diffstat is already the newest version.
gawk is already the newest version.
libtool is already the newest version.
texinfo is already the newest version.
build-essential is already the newest version.
git is already the newest version.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
gcc-multilib : Depends: gcc-4.6-multilib (>= 4.6.3-1~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
please provide me a step by step process
Community Manager
Hello Ayyappan91,
Thanks for reaching out!
You can download the source from https://iotdk.intel.com/src/3.5/edison/.
The following steps have been tested by a couple of users and myself in https://communities.intel.com/thread/111630: https://communities.intel.com/thread/111630:
Make sure you are using Ubuntu 14.04 (I tested this steps on kernel version 4.4.0-38-generic) and have the following versions of Git, tar, and Python:
Git 1.7.8 or greater
tar 1.24 or greater
Python 2.7.3 or greater excluding Python 3.x, which is not supported.
Install all the dependencies with the command:
sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \
build-essential chrpath socat libsdl1.2-dev xterm
Download and unzip iot-devkit-yp-poky-edison-20160606.zip ( http://iotdk.intel.com/src/3.5/edison/iot-devkit-yp-poky-edison-20160606.zip).
Go to iot-devkit-yp-poky-edison-20160606/poky/meta-intel-edison/meta-intel-edison-distro/recipes-core/images/edison-image.bb and comment or delete the following lines:
IMAGE_INSTALL += "iotkit-comm-js"
IMAGE_INSTALL += "iotkit-comm-c-dev"
Go to http://git.yoctoproject.org/cgit/cgit.cgi/meta-java/commit/recipes-core/icedtea/openjdk-7-03b147/sig...
Download the patch and unzip it.
Go to iot-devkit-yp-poky-edison-20160606/poky/meta-java/recipes-core/ant and delete the file called ant-native_1.8.1.bb, replace it with the file with the same name found in /meta-java-master/recipes-core/ant/.
Go to iot-devkit-yp-poky-edison-20160606/poky/meta-java/recipes-core/icedtea/ and delete the file called icedtea7-native_2.1.3.bb, replace it with the file with the same name found in /meta-java-master/recipes-core/icedtea/.
Go to iot-devkit-yp-poky-edison-20160606/poky/meta-java/recipes-core/icedtea/openjdk-7-03b147/ and delete the file fix-checksums.patch, replace it with the file with the same name found in /meta-java-master/recipes-core/icedtea/openjdk-7-03b147/.
Go to iot-devkit-yp-poky-edison-20160606/poky/meta-intel-iot-devkit/recipes-connectivity/bacnet-stack and open the file called bacnet-stack_0.8.2.bb. Look for the line:
SRC_URI = " http://sourceforge.net/projects/bacnet/files/bacnet-stack/bacnet-stack-${PV}/bacnet-stack-${PV}.tgz \
And change it for:
SRC_URI = " https://svwh.dl.sourceforge.net/project/bacnet/bacnet-stack/bacnet-stack-0.8.2/bacnet-stack-0.8.2.tg... \
Then follow the usual steps:
cd iot-devkit-yp-poky-edison-20160606/poky/
source oe-init-build-env ../build_edison/
bitbake edison-image u-boot
../poky/meta-intel-edison/utils/flash/postBuild.sh .
zip -r toFlash.zip toFlash
If you have issues building the image, you can also check https://communities.intel.com/thread/111630 https://communities.intel.com/thread/111630, on the latter pages, a user provided new ways to build the image with newer kernels and some other add-ons.
I hope this information helps you,
Pedro M.
aselv1
Good day
I have finsihed the process that you have explained me but i have faced some error while
its showing permission denied
please re type what i have to type in clearly
i have to type both source or-init-build-env../build_edison/
i cant build the image why its show trouble is their any steps for involving in building the parttions.
if i want to remove this please provide me the detailed informations
thanks in advance
Community Manager
Could you please share the error message with us? It is very strange that you got a permission denied message, I have never seen this personally. Are you the administrator or the PC that you're using? Or, is this PC perhaps owned by your school and limit your account in some way?
Anyway, please do share the error message, it will be of much help.
Pedro M.
Community Manager
Hello Ayyappan91,
Do you have any updates about this?
Pedro M.
aselv1
Good day I have tried I can't done to increase the root size
If possible can you increase the root memory for 2.5 gb and give me the image
Kindly do me a favour I can't create or build my image
Please help me with this
Community Manager
Hi Ayyappan91,
I'm confused, you mentioned that you want to change the partition of the Edison but on the steps you shared, it seemed as if you were trying to build Edison's image, that's why I shared with you the steps I used to build the image.
Unfortunately, I'm not able to build the image for you. If you are interested in changing the partition sizes of the image you indeed need to build the image but you have to take into consideration this document:
https://www.intel.com/content/www/us/en/support/boards-and-kits/000005955.html
Nevertheless, please try building the image with the steps I shared plus the information in that document. Make sure you are using Ubuntu 14, the instructions do not work on Ubuntu 16. If you have any issues, please post the error message here and we'll try to help you.
Pedro M.
