Intel® Makers
9872 Discussions
pip installation on edison
sk23
New Contributor II
Hi Intel Support team ,
I want to install pip and setuptools.I tried steps on below link but unable to install pip and setuptools.
http://blog.salvius.org/2015/05/installing-pip-on-intel-edison.html Installing PIP on the Intel Edison
Please help me.
Community Manager
Hi IoT_srinivas,
I've installed pip and setuptools successfully. Please follow the instructions below:
1. Setup the Edison repo by replacing anything you have in the /etc/opkg/base-feeds.conf file with the following:
src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all src/gz edison http://repo.opkg.net/edison/repo/edison http://repo.opkg.net/edison/repo/edison src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32 http://repo.opkg.net/edison/repo/core2-32
2. Setup the IoT repo by running the following commands:
echo "src intel-iotdk http://iotdk.intel.com/repos/3.0/intelgalactic/opkg/i586 http://iotdk.intel.com/repos/3.0/intelgalactic/opkg/i586" > /etc/opkg/intel-iotdk.conf
3. Run the following command: opkg update
4. Install pip by running the following commands:
wget https://bootstrap.pypa.io/get-pip.py https://bootstrap.pypa.io/get-pip.py --no-check-certificate
python get-pip.py
5. Install setuptools by running the following commands:
wget --no-check-certificate https://bootstrap.pypa.io/ez_setup.py https://bootstrap.pypa.io/ez_setup.py
python ez_setup.py --insecure
Hope this helps you.
Diego
FTinetti
Honored Contributor I
Hi IoT_srinivas,
I think you should post this in the Edison forum, this is the Galileo one. I think both cards are very similar, though, but I think it's better if you should take advantage of the specific forum : ) )
Fernando.
Community Manager
Hi IoT_srinivas,
python get-pip.py
Diego
