Intel® Makers
9873 Discussions
portaudio on Eclipse Intel System Studio
JOvie1
Hello. How can I use portaudio on intel system studio? It's intalled on intel galileo gen1, in the path /opt/snd/include/portaudio.h but I do not know how to include it on the ide to work with it.
Really I need help with it
Community Manager
Hi Julian,
I'm not quite sure if PortAudio is already installed in the Galileo, but if not, you can configure your Galileo to fetch packages from the AlexT repository, which has that package. So if you need instructions on that check this link http://alextgalileo.altervista.org/package-repo-configuration-instructions.html http://alextgalileo.altervista.org/package-repo-configuration-instructions.html.
Regarding the use of PortAudio, have you checked their tutorials on how to use it? If you don't have any luck with the process above you can build it from source, you'll find the instructions in there for Linux. After that you'll find a section on how to program with PortAudio, you'll need to run their examples to get a better idea of its usage.
PortAudio: http://portaudio.com/docs/v19-doxydocs/tutorial_start.html http://portaudio.com/docs/v19-doxydocs/tutorial_start.html.
Check this thread too http://comments.gmane.org/gmane.comp.audio.portaudio.devel/6666 http://comments.gmane.org/gmane.comp.audio.portaudio.devel/6666.
-Pablo
Community Manager
Hi Julian,
-Pablo
