Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
problems in building the image of the edison
Jump to solution
hello,everyone!
When I build the image of the edison board,I meet some problems.My os is Ubuntu14.04.
The errors are below:
extpoll
| -- Up-to-date: /home/chaos/edison/edison-src/build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/image/usr/bin/libwebsockets-test-client
| -- Installing: /home/chaos/edison/edison-src/build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/image/usr/bin/libwebsockets-test-fraggle
| -- Installing: /home/chaos/edison/edison-src/build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/image/usr/bin/libwebsockets-test-ping
| -- Installing: /home/chaos/edison/edison-src/build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/image/usr/bin/libwebsockets-test-echo
| -- Installing: /home/chaos/edison/edison-src/build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/image/usr/share/libwebsockets-test-server/favicon.ico
| -- Installing: /home/chaos/edison/edison-src/build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/image/usr/share/libwebsockets-test-server/leaf.jpg
| -- Installing: /home/chaos/edison/edison-src/build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/image/usr/share/libwebsockets-test-server/libwebsockets.org-logo.png
| -- Installing: /home/chaos/edison/edison-src/build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/image/usr/share/libwebsockets-test-server/test.html
| CMake Error at cmake_install.cmake:189 (FILE):
| file INSTALL cannot find
| "/home/chaos/edison/edison-src/build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/build/libwebsockets-test-server.key.pem".
| make: *** [install] Error 1
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_install (log file is located at /home/chaos/edison/edison-src/build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/temp/log.do_install.19402)
ERROR: Task 518 (/home/chaos/edison/edison-src/device-software/meta-edison-distro/recipes-connectivity/libwebsockets/libwebsockets_1.23.bb, do_install) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1872 tasks of which 1863 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
How can I solve the problem?Do anyone can help me?
Accepted Solutions
Highlighted
Re: problems in building the image of the edison
Jump to solution
That's a known bug, see this post and further down, there's a solution if you don't want to change the Ubuntu to x86_64 (which I'd recommend to do anyway):
Highlighted
Jump to solution
Hi cer1991,
I'd suggest you to use a 64 bit Ubuntu in case you are using a 32 bit version. Also you could try updating cmake to the latest version and to start the build from scratch again. I hope this helps
JPMontero_Intel
Highlighted
1 View
Jump to solution
Highlighted
Jump to solution
Hi,JPMontero_Intel
I have solved the problem.
Thank you!
Highlighted
Jump to solution
Hi,AlexT_Intel
I have sloved the problem.
Thank you!
Highlighted
Jump to solution
Hi cer1991,
Could you let us know how you solve the issue?
JPMontero_Intel
Highlighted
Jump to solution
HI,@JPMontero_Intel
When you meet the error, you need to navigate to build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/build and call "cmake ."
You can read for more.
