Intel® Makers
9880 Discussions
problems to use python-smbus to control driver i2c of the Openelectrons
nDE_S
Hi guys,
Following this site: https://communities.intel.com/thread/61160 https://communities.intel.com/thread/61160
I do this:
pip install cffi
and then:
pip install smbus-cffi
After I tried install run python scrit to detect i2c address in my intel edison and I have error with python-smbus
root@edisonb:~/opt# python explorer1.py
Connect I2C device...
Traceback (most recent call last):
File "explorer1.py", line 31, in
i2c = explorerlib.Explorer(addr)
File "/home/root/opt/explorerlib.py", line 35, in __init__
OpenElectrons_i2c.__init__(self, explorer_address >> 1)
File "/home/root/opt/OpenElectrons_i2c.py", line 57, in __init__
self.bus = smbus.SMBus(b)
File "/usr/lib/python2.7/site-packages/smbus/smbus.py", line 56, in __init__
self.open(bus)
File "/usr/lib/python2.7/site-packages/smbus/smbus.py", line 83, in open
raise IOError(e.errno)
IOError: 2
Help me please
Sergio_A_Intel
When you ran the first two commands did you receive any errors? What image are you using? What are the contents of explorer1.py?
Sergio
nDE_S
Hi Sergio
root@edisonb:~/opt/i2c-tools# configure_edison --version
159
But I think the problem is not this.
explorer1.py
# !/usr/bin/env python
# Copyright (c) 2014 OpenElectrons.com
# Explorer example script.
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License version 2 as
# published by the Free Software Foundation.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
# History:
# Date Author Comments
# 04/15/14 Michael Initial authoring.
import time
import os, sys
import explorerlib
print "Connect I2C device..."
time.sleep(3)
addr = 0x00 # DO NOT change this address!!!
found = i2c.ping(0x00)
# Checks for connection on all I2C addresses until connection is found
while found == -1:
if (addr < 0xef):
addr = addr + 1
else:
addr = 0x00
print "--------------------"
print "7 bit address: " + str(hex(addr/2)) # RaspberryPi will find device at this address
print "8 bit address: " + str(hex(addr)) # Use this address for use with OpenElectrons_i2c.py
print i2c.GetFirmwareVersion()
print i2c.GetVendorName()
print i2c.GetDeviceId()
# Press Pause/Break button on your keyboard to stop the program
root@edisonb:~/opt/i2c-tools# i2cdetect -y -r 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: UU UU UU UU -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@edisonb:~/opt/i2c-tools# i2cdetect -y -r 6
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
Other attempt is this: /thread/52982 https://communities.intel.com/thread/52982
everything was going well until:
root@edisonb:~/opt/i2c-tools# make install
install -m 755 -d /usr/local/include/i2c
make: install: Command not found
include/Module.mk:19: recipe for target 'install-include' failed-- -- -- -- -- --
make: *** [install-include] Error 127
nDE_S
My Smartdrive board (http://www.mindsensors.com/rpi/76-smartdrive-high-current-motor-controller?search_query=Smartdrive&r... SmartDrive High Current Motor Controller) still not detected in i2cDETECTS commands. Using m2ctool and i2cdetect. What I can do now
still not detected~
Sergio_A_Intel
How are you powering the smart drive motor controller and the Edison? From what link did you downloaded the code, this code is not going to work on the Edison without making some changes first. If you look at the comments on the print statements you'll notice this code and the motor controller were designed for a Raspberry Pi so the addresses that I2C will use to communicate will not be the same for the Edison.
Also, if you want to install i2c-tools why not try downloading and installing with opkg: opkg install i2c-tools
Sergio
nDE_S
I've done this and more: opkg install i2c-tools
Will I need this : /thread/52982 https://communities.intel.com/thread/52982 ?
What about this error in that site:
below pictures of i2c connections that tried. With and without GROVE KIT. I use A4/27 and A5/28 = i2c1 and A4/27 and A5/28 i2c6
nDE_S
Now I can. I2C 7 bit address of datasheet
nDE_S
I need now know commands to run motor 1/motor 2 in linux shell commands using i2c
Sergio_A_Intel
Were you able to run the make command without issues? You can also find several commands that work for this sensor in http://www.mindsensors.com/index.php?controller=attachment&id_attachment=121 http://www.mindsensors.com/index.php?controller=attachment&id_attachment=121
Sergio
nDE_S
Sergio,
I can't run make command. I need explorer1.py
Sergio_A_Intel
Run the command opkg install make to install make and try again.
Sergio
nDE_S
Sergio,
root@edisonb:~/opt/i2c-tools# make EXTRA="py-smbus"
cd py-smbus && python setup.py build
running build
running build_ext
root@edisonb:~/opt/i2c-tools# opkg install make
Package make (4.0-r0) installed in root is up to date.
root@edisonb:~# pwd
/home/root
root@edisonb:~# opkg install make
nDE_S
Solved
Thank's All right
