Intel® Makers
9881 Discussions
pthread on edison - undefined reference to symbol?
CBrou1
I am using the Eclipse IDE.
I have been trying to use the pthread library and I am getting a linker error:
... undefined reference to symbol 'pthread_create@@GLIBC_2.1'
(i have tried on two different eclipse installations on two different machines with the same result)
Any idea ?
Carlos_M_Intel
Hi CABrouwers,
Which Eclipse IDE version are you using?
Which code are you using?
Could you post a screenshot of the entire error message?
I'm using Eclipse Version: Luna SR2 (4.4.2) (Help > About Eclipse Platform)
Edison image version: 159.devkit (configure_edison --version)
I'm using the following example and had no problems:
# include
# include
# define NUM_THREADS 5
void *PrintHello(void *threadid)
long tid;
tid = (long)threadid;
printf("Hello World! It's me, thread # %ld!\n", tid);
pthread_exit(NULL);
int main (int argc, char *argv[])
pthread_t threads[NUM_THREADS];
int rc;
long t;
for(t=0; t
printf("In main: creating thread %ld\n", t);
rc = pthread_create(&threads[t], NULL, PrintHello, (void *)t);
if (rc){
printf("ERROR; return code from pthread_create() is %d\n", rc);
/* Last thing that main() should do */
pthread_exit(NULL);
Then I added the linker flag –pthread. By doing right click on the project > Properties > C/C++ Build > Settings > Cross GCC Linker > Miscellaneous and adding –pthread on Linker flags. After this, click on Apply and OK.
Let me know if this works for you.
Charlie
Carlos_M_Intel
Hi CABrouwers,
# include
# include
long tid;
pthread_exit(NULL);
int rc;
long t;
for(t=0; t
if (rc){
pthread_exit(NULL);
Charlie
CBrou1
Thanks for response.
I copies the code in a new project and set the linker flag as you indicated.
Now, I get the following error message:
The program file specified in the launch configuration does not exist
C:\Users\xxxxxx\workspace_iot\Testhread\Debug\Testhread not found
I will do further test later ... but perhaps you have idea now ?
Happy New Year !
CBrou1
Finally, I got it to work ! It took me a little while though.
In order to avoid making a spelling error, i was copying the -pthread flag from your post.
When I built I would get a pop up error message:
C:\Users\xxxxx\workspace_iot\test\Debug\test not found
However, when I typed -pthread myself, everything turned out fine !
I assume was unknowingly copying some hidden characters that confused the linker!
(probably something that should be fixed in Eclipse)
Thanks a lot for your help!
