Intel® Makers
9867 Discussions
python import error:-
Community Manager
Hello everyone,
I'm trying to run a program which uses keyboard event.
basically i want to run specific bash script when I press a particular key.
my python program name is "command.py"
when I press "F" key then first bash script "first.sh" should run.
when I press "S" key then second bash script "second.sh" should run.
but it returns an error:
ImportError: No module named msvcrt
msvcrt is for windows and not for python so now what should i do to take keyboard key pressed ??
my program is like below:
____________________________________________________________________________________________________________
# !/usr/bin/python
import threading
import msvcrt
import subprocess
class myThread (threading.Thread):
def __init__(self, name):
threading.Thread.__init__(self)
self.name = name
def run(self):
process(self.name)
def process(threadname):
identity=threadname
if(identity=="first"):
# if second.sh is running, then kill second.sh & start first.sh
killall second.sh
subprocess.call("first.sh")
elif(identity=="operation"):
# if first.sh is running, then kill second.sh & start first.sh
killall first.sh
subprocess.call("second.sh")
# Create new threads
thread1 = myThread("first")
thread2 = myThread("second")
# Start new Threads
thread1.start()
thread2.start()
Carlos_M_Intel
Hi Falak,
Have you tried with call systems instead of using subprocess, something like:
import os
code = os.system('sh /home/root/first.sh')
Charlie
Carlos_M_Intel
Hi Falak,
import os
Charlie
