Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
python-opencv can't import cv2
Jump to solution
Hi
I build an full image for Galileo, and want to use python-opencv for some detection things.
However, I tried to import cv2 for python-opencv but failed with below errors.
is there any possible fix for that?
thanks a lot!
root@clanton:~# python
Python 2.7.3 (default, May 10 2014, 15:49:21)
[GCC 4.7.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
/usr/bin/python2.7: symbol 'th_comment_query_count': can't resolve symbol in lib '/usr/lib/libtheoraenc.so.1'.
Traceback (most recent call last):
File "", line 1, in
ImportError: unknown dlopen() error
Tags (1)
Accepted Solutions
Highlighted
Looks like you are building the uclibc version of the SD card image: that's the same error I got when trying the uclibc build.
opencv does not work in the uclibc build.
You need to rebuild the SD card image to use eglibc by following the instructions here: http://www.malinov.com/Home/sergey-s-blog/intelgalileo-buildinglinuximage Intel Galileo - Building Linux Image - Malinov Family Web Presence
or by build the IoT image which is here: http://git.yoctoproject.org/cgit/cgit.cgi/meta-intel-iot-devkit/ meta-intel-iot-devkit - Intel IoT Developer Kit metadata
Python bindings for opencv work fine in the eglibc build
Highlighted
Highlighted
Community Manager
thanks a lot.
I will give it a try.
Highlighted
Community Manager
it works for me to change from uclibc to eglibc.
thanks!
Highlighted
Could you share your eglibc-based image? Or someone already shared it?
Highlighted
New Contributor II
HI @Liam,
Do you also have an idea how can we run python opencv on uclibc image? (I am using http://repo.opkg.net/galileo/images/image-devtools-1.0.4-1.tar.bz2 http://repo.opkg.net/galileo/images/image-devtools-1.0.4-1.tar.bz2)
