Hi, the pdf http://download.intel.com/support/edison/sb/edison_nag_331192003.pdf http://download.intel.com/support/edison/sb/edison_nag_331192003.pdf says we can cross build app using edison toolchain.
source /opt/poky-edison/1.6/environment-setup-core2-32-poky-linux
But when the app use python during its building, like nodejs, iotjs and so on, it always throw error when building.
Take nodejs as an example:
jzd@jzd32:~/Downloads/node-v4.0.0$ ./configure
Traceback (most recent call last):
File "./configure", line 7, in
import subprocess
ImportError: No module named subprocess
without checking the toolchain I'd suspect it doesn't support Python out of the box. Just check whether there is a /usr/lib/python2.7 or so contained in the toolchain.
Alternatives for instance:
- compile on target
- compile in a chroot environment to possibly accelerate the compilation - just "sudo mount edison-image-edison.ext4 /mnt -o loop && sudo chroot /mnt" in a Linux shell
Hi jzd,
Which BSP did you used to build the toolchain?
Are you compiling the code using the toolchain? Or are you compiling using your PC resources?
Did you check if you have the folder /usr/lib/python2.7?
Charlie
Hi Charlie
1, I directly download the toolchain from http://downloadmirror.intel.com/25028/eng/edison-sdk-linux32-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-sdk-linux32-ww18-15.zip
2, I compile the code after using `source environment-setup-core2-32-poky-linux`
3, yes, my host pc has the folder /usr/lib/python2.7
Zidong
But, are you using Python from the PC or from the Yocto image? Enter into the Ubuntu terminal and type python. In the python prompt type import subprocess. Do you still see the same error?
Sergio
when after type "source /opt/poky-edison/1.6/environment-setup-core2-32-poky-linux", the python path will be the one in yocto image.
I can see the same problem in yocto image's python shell when import subprocess.
Can you reproduce the problem?
1, I directly download the toolchain from http://downloadmirror.intel.com/25028/eng/edison-sdk-linux32-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-sdk-linux32-ww18-15.zip and install it
2,`source environment-setup-core2-32-poky-linux
3, enter python shell and "import subprocess"
Do you see the same behavior with the newest version http://downloadmirror.intel.com/25028/eng/edison-sdk-linux32-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-sdk-linux32-ww25.5-15.zip ?
Sergio
Hi jzd,
Have you been able to successfully use python in with the toolchain?
Did you try with the latest version? Or do you want to use the ww18-15?
Charlie
Hi Sergio and Charlie
I just tried the newest version http://downloadmirror.intel.com/25028/eng/edison-sdk-linux32-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-sdk-linux32-ww25.5-15.zip
it CAN import subprocess now, but it CANNOT import filecmp.
I mainly use node-v4.0.0 configure file to test the toolchain
I found a workaround that lets me run import subprocess and import filecmp without any errors. I changed the file path of PYTHONHOME in /opt/poky-edison/1.7.2/environment-setup-core2-32-poky-linux.
cat /opt/poky-edison/1.7.2/environment-setup-core2-32-poky-linux
PYTHONHOME=/opt/poky-edison/1.7.2/sysroots/i686-pokysdk-linux/usr
Try with these changes and let me know your results.
Sergio
I am confused. the PYTHONHOME in /opt/poky-edison/1.7.2/environment-setup-core2-32-poky-linux is exactly what you write
jzd@jzd32:/opt/poky-edison/1.7.2$ cat environment-setup-core2-32-poky-linux | grep PYTHON
export PYTHONHOME=/opt/poky-edison/1.7.2/sysroots/i686-pokysdk-linux/usr
So nothing need to modify.
That was a mistake, the path I wanted to suggest was export PYTHONHOME=/opt/poky-edison/1.7.2/sysroots/core2-32-poky-linux/usr
Sergio
