Hi.
I am trying to use Intel® QuarkTM SE Microcontroller C1000 Development Platform.
So I followed Get Started link below.
https://software.intel.com/en-us/iot/hardware/C1000/get-started Get Started with the Intel® Quark™ SE microcontroller C1000 | IoT | Intel® Software
But i failed in step 3. c. follow the gaetting started of ISSM welcome page.
I got error massage when Update Microcontroller ROM
Could not update the ROM. Flash ROM failed.
Open On-Chip Debugger 0.8.0-dev-gba72ade-dirty (2016-07-19-11:13)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html http://openocd.sourceforge.net/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
adapter speed: 1000 kHz
trst_only separate trst_push_pull
jtag_ntrst_delay: 300
Info : clock speed 1000 kHz
Info : JTAG tap: quark_se.cltap tap/device found: 0x0e765013 (mfg: 0x009, part: 0xe765, ver: 0x0)
Enabling arc core tap
Info : JTAG tap: quark_se.arc-em enabled
Enabling quark core tap
Info : JTAG tap: quark_se.quark enabled
Processor type: arc-em
redirect to PM, tapstatus=0x00300c14
unknown break reason at 0x0000fff0
Setup clock
adapter speed: 4 kHz
target state: halted
target halted due to debug-request at 0x0000fff0 in real mode
target running for unknown reason
target halted due to debug-request at 0xffffe29d in protected mode
Start flash
My development environment is Windows 7
Connect usb on FTD_USB only
Can find OpenOCD JTAG from Windows Device manager
Try grounding J14 Pin 28 on the board but fail
And I did run the LED blink example with a previous version of ISSM few months ago
If I ignore the above error, build and run the LED blink example, there is no error and i can see 1.26KiB Flash1 used, 80B SRAM used but no led blinking.
And on hello world example, i can only "?" on Serial Terminal of ISSM.
How can i fix the problem?
Jeong
Jeong Hasang 님이 메시지를 편집했습니다.
I fixed problem follow link below.
https://software.intel.com/en-us/node/704893 IoT - Troubleshooting | Intel® Software
